BUFFALO BRUHD-PU3-BK not flashing at all!
I have downgraded my BUFFALO BRUHD-PU3-BK once and it has been working fine but recently, it is giving me all sorts of issues reading UHD discs.
I thought to flash it to 1.03 MK firmware but Asus modified tool gives me Updating Failure #5 error and SDFtool seems to flash fine BUT no real effect appears. Firmware is still the same and doesn't change.
What can I do to really flash my drive to 1.03 and is it the best firmware for my drive?
Here is a screenshot for my drive's specs:
Re: BUFFALO BRUHD-PU3-BK not flashing at all!
Follow the guide Asus tool is not the current method guide linked below
I did follow the guide and used SDFtool but it has no effect at all even though it shows FW has been updated.Billycar11 wrote: ↑Wed May 15, 2024 1:12 amFollow the guide Asus tool is not the current method guide linked below
Then use the cli method that always works
It could be the Buffalo case. You may need to remove the drive.r9800pro wrote: ↑Wed May 15, 2024 2:53 pmI did follow the guide and used SDFtool but it has no effect at all even though it shows FW has been updated.Billycar11 wrote: ↑Wed May 15, 2024 1:12 amFollow the guide Asus tool is not the current method guide linked below
For UHD enabled drives (AU/NZ/SG) & DIY Single Drive Flasher (WW): https://www.uhdenableddrives.com
it can be done in the buffalo case they just need the right steps enc vs no enc
Could you please direct me to the right steps?Billycar11 wrote: ↑Thu May 16, 2024 1:40 amit can be done in the buffalo case they just need the right steps enc vs no enc
I tried CLI and got this error:
Internal error 0x83000001
post cli output not just the errorr9800pro wrote: ↑Thu May 16, 2024 5:24 pmCould you please direct me to the right steps?Billycar11 wrote: ↑Thu May 16, 2024 1:40 amit can be done in the buffalo case they just need the right steps enc vs no enc
the guide has the exact steps see below
you could also get an auto flasher kit from me
PS C:\> cd "C:\Program Files (x86)\MakeMKV"Billycar11 wrote: ↑Thu May 16, 2024 11:29 pmpost cli output not just the errorr9800pro wrote: ↑Thu May 16, 2024 5:24 pmCould you please direct me to the right steps?Billycar11 wrote: ↑Thu May 16, 2024 1:40 amit can be done in the buffalo case they just need the right steps enc vs no enc
PS C:\Program Files (x86)\MakeMKV> makemkvcon64.exe f --all-yes -d :G : rawflash -i C:\ DE_LG_BU40N_1.03_MK.bin
makemkvcon64.exe : The term 'makemkvcon64.exe' is not recognized as the name of a cmdlet, function, script file, or
operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try
again.
At line:1 char:1
+ makemkvcon64.exe f --all-yes -d :G : rawflash -i C:\ DE_LG_BU40N_1.03 ...
+ CategoryInfo : ObjectNotFound: (makemkvcon64.exe:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
Suggestion [3,General]: The command makemkvcon64.exe was not found, but does exist in the current location. Windows PowerShell does not load commands from the current location by default. If you trust this command, instead type: ".\makemkvcon64.exe". See "get-help about_Command_Precedence" for more details.
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d :G : rawflash -i C:\ DE_LG_BU40N_1.03_MK.bin
Input file not found -- C:\
Well makemkv is not installed in the default location that's your issuer9800pro wrote: ↑Fri May 17, 2024 5:59 pmPS C:\> cd "C:\Program Files (x86)\MakeMKV"Billycar11 wrote: ↑Thu May 16, 2024 11:29 pmpost cli output not just the error
again.
At line:1 char:1
Billycar11 wrote: ↑Fri May 17, 2024 9:05 pmWell makemkv is not installed in the default location that's your issuer9800pro wrote: ↑Fri May 17, 2024 5:59 pmPS C:\> cd "C:\Program Files (x86)\MakeMKV"Billycar11 wrote: ↑Thu May 16, 2024 11:29 pm
again.
At line:1 char:1
Okay, reinstalled makemkv and flashed the drive and it said operation finished successfully BUT... drive still shows the old FW so it seems the flashing actually did NOTHING.PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d G: rawflash -i H:\DE_LG_BU40N_1.03_MK.bin
Reading input file H:\DE_LG_BU40N_1.03_MK.bin
Current Drive ID: BUFFALO_Optical_Drive_1.00_211711211720_MO6MC7A0333
100% Operation finished
Done successfully
Ok let's see the input and output again and your makemkv drive info section
Billycar11 wrote: ↑Sat May 18, 2024 10:11 pmOk let's see the input and output again and your makemkv drive info section
Use imgur or just copy paste the text nothing is showing up for the imager9800pro wrote: ↑Mon May 20, 2024 5:36 pmBillycar11 wrote: ↑Sat May 18, 2024 10:11 pmOk let's see the input and output again and your makemkv drive info section
Sorry about that. Fixed now.Billycar11 wrote: ↑Mon May 20, 2024 7:24 pmUse imgur or just copy paste the text nothing is showing up for the imager9800pro wrote: ↑Mon May 20, 2024 5:36 pmBillycar11 wrote: ↑Sat May 18, 2024 10:11 pm
