inb4 the wat i do with privatedata.tard00zah wrote: ↑Tue Dec 12, 2023 10:24 pmC'mon! Really?
Woodstock wrote: ↑Tue Sep 15, 2020 1:19 pmThe file itself should be automatically downloaded when you start a rip; On disk, it is added to _private_data.tar in your MakeMKV data directory.
If you want to manually download it, https://makemkv.com/sdf.bin will fetch it.
Be aware that sdf.bin does not contain the hashed keys for UHD decoding; it DOES contain the current link to it, though.
SDF.bin
Re: SDF.bin
Re: SDF.bin
Yes really! It says specifically don't contain the hash key for uhd, so I take it as just that.
To put it an a specific folder?
Re: SDF.bin
Buzzlite1926 wrote: ↑Tue Dec 12, 2023 10:51 pmYes really! It says specifically don't contain the hash key for uhd, so I take it as just that.
It doesn't explicitly say it, but the .bin should be dropped in the MakeMKV data directory, which by default, is (in Windows, unless changed by user):Woodstock wrote: ↑Tue Sep 15, 2020 1:19 pmThe file itself should be automatically downloaded when you start a rip; On disk, it is added to _private_data.tar in your MakeMKV data directory.
%UserProfile%\.MakeMKV
Unless somehow blocked, or disabled, all this SHOULD all happen automagically.
I surrender!
