BU40N - AACS host certificate is revoked
Re: BU40N - AACS host certificate is revoked
With libredrive the mkb version is irrelevant. That firmware is perfect and what I use on my own drive.
The AACS version has nothing to do with the firmware either. The only reason you would ever consider updating the firmware is if you burn a lot of discs and the drive isn't working particularly well with a certain brand of blank media. So, no, never update it.BlvckBytes wrote: ↑Mon Aug 28, 2023 10:19 amI'm just curious about the fact that my highest AACS version is 61, while I have seen (on YouTube, I think) there being Blu-Ray discs of higher AACS version. This is what I meant with "that this firmware can't read". Obviously, damaged or dirty media is going to have nothing to do with the firmware.MartyMcNuts wrote: ↑Mon Aug 28, 2023 9:19 amYou are already on the best firmware for that drive. Leave it on 1.00. If you have trouble reading a disc, clean the disc.
For UHD enabled drives (AU/NZ/SG) & DIY Single Drive Flasher (WW): https://www.uhdenableddrives.com
Thanks for clearing that one up for me! I have no significant knowledge on any of this as I'm very new to the whole space of disks in general (was never greatly interested, until very recently). I just noticed that the "highest AACS version" went up, since the media's version went up. Seems like this is not set in stone, and I successfully read that one also. Good to know!MartyMcNuts wrote: ↑Mon Aug 28, 2023 11:01 amThe AACS version has nothing to do with the firmware either. The only reason you would ever consider updating the firmware is if you burn a lot of discs and the drive isn't working particularly well with a certain brand of blank media. So, no, never update it.
Each disc has an AACS revision. When you insert a disc and the drive initializes it, if the disc has a higher AACS revision than what the drive has seen previously, it updates itself to the version that is on the disc. You may notice this happens every now and then when you purchase the latest release movie discs.BlvckBytes wrote: ↑Tue Aug 29, 2023 11:43 amThanks for clearing that one up for me! I have no significant knowledge on any of this as I'm very new to the whole space of disks in general (was never greatly interested, until very recently). I just noticed that the "highest AACS version" went up, since the media's version went up. Seems like this is not set in stone, and I successfully read that one also. Good to know!MartyMcNuts wrote: ↑Mon Aug 28, 2023 11:01 amThe AACS version has nothing to do with the firmware either. The only reason you would ever consider updating the firmware is if you burn a lot of discs and the drive isn't working particularly well with a certain brand of blank media. So, no, never update it.
Unless you only ever use libredrive to read the disc.
The AACS revision on the drive should still update like normal, it just doesn't get revoked when using LibreDrive.
Are you sure? If you never authenticate with the drive my understanding was it didn't update. I could be wrong I suppose.
My drive has only ever been used in a LibreDrive way, but the AACS version is 78. So I think MartyMcNuts is right, the AACS updates, but LibreDrive means it doesn't matter.
i think just putting the disc in updates it
Odd. I really hate aacs. It's an overly complicated mess of a house of cards. Simply inserting a disc should not update the drive in any way. But oh well. Hardly matters in reality.
Yes, as soon as the drive begins to initialize a disc, the AACS revision is checked and updated if necessary.
Manufacturer: hp
Product: BD E DS6E2LH
Revision: FH62
Bus encryption flags: 1A
Highest AACS version: 76
Disc Information
Label: CE3K
Timestamp: 2007-09-25 17:47:27
Protection: AACS v4
Data capacity: 46.28 Gb
Disc type: BD-ROM
Number of layers: 2
Manufacturer: hp
Revision: FH62
Disc Information
Label: CE3K
Protection: AACS v4
Disc type: BD-ROM
Number of layers: 2
Manufacturer: hp
Revision: FH62
Disc Information
Label: CE3K
Protection: AACS v4
Disc type: BD-ROM
Number of layers: 2
Title information
Name: Close Encounters of the Third Kind Ultimate Edition-
Source file name: 00056.mpls
Duration: 2:17:14
Chapters count: 20
Segment count: 29
Segment map: 0,2,6,8,9,12,13,15,16,19,20,21,24,25,26,28,118,119,32,33,34,37,39,40,42,43,45,46,49
File name: Close Encounters of the Third Kind Ultimate Edition-_t02.mkv
Evaluation version, evaluation period expired 7 day(s) ago
Title #00111.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00202.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00054.mpls was added as title #0
File 00055.mpls was added as title #1
File 00056.mpls was added as title #2
File 00227.mpls was added as title #3
Title #00058.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Video/Close Encounters of the Third Kind Ultimate Edition-
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '0'
Failed to save title 2 to file C:/Video/Close Encounters of the Third Kind Ultimate Edition-/Close Encounters of the Third Kind Ultimate Edition-_t02.mkv
Encountered 1 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Manufacturer: hp
Revision: FH62
Disc Information
Label: CE3K
Protection: AACS v4
Disc type: BD-ROM
Number of layers: 2
Title information
Duration: 2:17:14
Chapters count: 20
Segment count: 29
I'm not sure what you're asking? Or why you're asking in this thread?lordthunder77 wrote: ↑Wed Feb 28, 2024 9:54 pmError 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '0'
Those errors mean the optical drive was unable to correctly read the optical disc. The standard advice is to gently clean the disc and try again.
