Barbie 4K
RasterEyes
Re: Barbie 4K
Post by RasterEyes »
A general question about discs that need new decryption keys:
Do you need to update the MakeMKV application itself to handle such discs, once someone figures out the needed decryption, or does MakeMKV "phone home" to get the new key without having to be updated?
Re: Barbie 4K
Post by d00zah »
RasterEyes wrote:
Wed Oct 18, 2023 6:51 pm
From the UHD FAQ (recommended read):
How does MakeMKV work with UHDs?
MakeMKV uses Hashed Keys. Originally supplied via a download, MakeMKV now updates automatically. Go to View / Preferences / General and ensure that "Enable Internet access" is checked.
arules99
Re: Barbie 4K
Post by arules99 »
Attaching dump of file MKB20_v77_Barbie_F028.tgz
Gertting "cannot decrypt" error.
Amazon 4k UHD disk.
Pleae advise as to when a new patch is available.
Re: Barbie 4K
arules99 wrote:
Wed Oct 18, 2023 11:47 pm
Amazon 4k UHD disk.
Don't attach it here. You should email it to svq@makemkv.com. There won't be any notifications about it, just retry your disc every few days.
For UHD enabled drives (AU/NZ/SG) & DIY Single Drive Flasher (WW): https://www.uhdenableddrives.com
haec0007
Re: Barbie 4K
Post by haec0007 »
I have submitted the dump for MKB20_v77_BARBIE_5BD0.tgz
Sunoo
Re: Barbie 4K
Post by Sunoo »
MKB20_v77_Barbie_F028 is now working.
chrispgriffin
Re: Barbie 4K
Post by chrispgriffin »
Sunoo wrote:
Thu Oct 19, 2023 10:48 pm
Can confirm, as well!
WAYFLIX
Re: Barbie 4K
Post by WAYFLIX »
Working now.
Coopers
Re: Barbie 4K
Post by Coopers »
New error? MKB20_v77_Barbie_D876. Just sendt inn.
SvaLLe
Re: Barbie 4K
Post by SvaLLe »
I have a new one as well, which has been sent in by mail
MKB20_v77_Barbie_D876.tgz
SvaLLe
Re: Barbie 4K
Post by SvaLLe »
So I can confirm that MKB20_v77_Barbie_D876.tgz also works, thanks a lot guys :D
arcturus_
Re: Barbie 4K
Post by arcturus_ »
I am also having an issue with MKB20_v77_Barbie_5BD50 not having a known volume key, so I emailed the dump file. Anyone having success with this particular disc?
EDIT: Something on my network was blocking the automatic SDF downloading. I installed a VPN and had no further trouble ripping this disk.
creon
Re: Barbie 4K
Post by creon »
Got a volume key unknown error on the disc I just got.
Submitted MKB20_v77_Barbie_6D16.tgz yesterday.
saxman
Re: Barbie 4K
Post by saxman »
I also got a volume key unknown error on two discs I got (I re-ordered a second to make sure the disc wasn't just faulty). I submitted MKB20_v77_Barbie_4EAA for the second disc I received, which had the same hash as the first. Must be a new disc specific key in my area.
creon
Re: Barbie 4K
Post by creon »
MKB20_v77_Barbie_6D16.tgz now works. Thanks!
