Planet Earth III 4K - Dump Files Submitted
ColKurtz
Re: Planet Earth III 4K - Dump Files Submitted
Post by ColKurtz »
I am still unable to do so. I am getting the same as in the first post as this thread. can anyone suggest a reason why this may be? Thanks in advance.
ColKurtz wrote:
Tue Apr 16, 2024 11:59 pm
Can you copy & paste your MakeMKV log here?
ColKurtz
Post by ColKurtz »
Thank you for your replay. I used the workaround involving the download of FindVUK. That seems to have worked. May also have solved my Oppenheimer issue. If it would be helpful to others I can see if I can find the dump file and upload.
