The shield is sending LLDV only to the CX10
When u try & get default DV RGB8 no GO
U only get it to playback in 12bit 709 DV
Pink colors but only on the CX I also have a doblyvision vizo & tlc 6 doblyvision connected all at the same time & ONLY the CX can’t read the dv 422 709 dv being outputed from the shield.
This could be the vertex2 fault.
So I did the same with the sony X700
I use LLDV so much I had to force my Sony to play back to regular dv by selecting rgb in settings.
Vertex says dv rgb8 on lg/CX
So something is wrong with the shield & CX
Not communicating properly.
Could also be that I don’t have the latest firmware on the vertex2 for the cx-edid
There is b9 & c8 edid but none for the CX on my firmware.
So I’m going to try my atmos player & see what it reads the shield tv directly to tv
Yep something is wrong with the shield no dv8 bit rgb
Can someone ellse try c8 & 9
My onkyo receiver won’t connect to my shield as well or pass the signal true
Don’t know if it’s 2.1 doing this
Now I’m going to take the CX out from the tv equation completely.
See if I get dv-rgb 8 latest shield firmware.
- Colors u get on a none doblyvision set
CX does not show file while tlc& vizo plays in doblyvision. - 5E11A016-166E-43D6-A1F4-9A80EB7B7EC4.jpeg (3.42 MiB) Viewed 15337 times
- Vertex2 reading
- 12C58BF1-1FC2-4BF6-A9DA-160FB20E2D55.jpeg (797.18 KiB) Viewed 15337 times
It almost feels like the shield is missing BT2020-DV that they removed 2 software versions back is rearing its head.
Still RGB 8bit here on my B9. Latest 5.0 firmware on the TV and 8.2.1 on the Shield experience. Tested with both UHD disk backup DV and Netflix DV.
Sony /cx
On the CX shield behaves like the new Xbox that’s weird makes it own adjustments & CX sees it as a gaming machine, deep colors prompt u to turn off ect
This never happened to me before CX is only 3 weeks old taking the CX out off the equation & directly connected the shield is still not gaving me rgb8 dv from the shield
Even on my other doblyvision TVs.
Lol maybe my shield is broken lol
LLDV on shield is still good.
I’ll wait for other CX/shield owners to respond.
Has to be CX/shield hdmi hand shake On the CX shield behaves like the new Xbox that’s weird makes it own adjustments & CX sees it as a gaming machine, deep colors prompt u to turn off ect
Still getting RGB DV on both my Vizio TV and OLED C8... latest Shield firmware.
Since you're getting RGB from the x700, it sounds like the Shield has an issue with the CX. I would blame the Shield though, what a terrible device for DV, so many issues...
Like I said, the guy who tested my C9 edid said the LG was requesting LLDV from the Zidoo / Shield, don't know why it is different on the B9, the B9 and C9 don't have the same processor so might have different firmware.
Anybody want a try?
I think it was my vertex2 it replaces the edid so a lot of times when switching back & forth between settings edid gets locked in, powering down everything un plug still works lol.
Only difference this time my other 3 screens are gettingshield CX rgb8 doblyvision perfect shield second screen tlc black screen like the CX was getting 3rd
Screen vizo what the CX was getting before
12bit 709
But all this started happening recently well today ,it’s probably 2.1 hdmi in the loop
- 75B43623-C0BE-43E5-8B53-EA43B1CBF749.jpeg (2.95 MiB) Viewed 15312 times
- CC4EA98E-4A51-4548-B2DC-55628C44C59E.jpeg (3.33 MiB) Viewed 15312 times
Last edited by Manixx2020beyound on Fri Dec 04, 2020 11:12 pm, edited 3 times in total.
Hi, how did you get it to work, attached my edid on a previous post.
There's an easy way to just test this on your own. Play some DV content on your Shield, and then open up the HDMI diagnostics menu on your C9 and check what kind of signal it's receiving. No need to worry about what anyone else's HDFury is reporting when you can get it directly from your TV.DaMacFunkin wrote: ↑Fri Dec 04, 2020 10:43 pmLike I said, the guy who tested my C9 edid said the LG was requesting LLDV from the Zidoo / Shield, don't know why it is different on the B9, the B9 and C9 don't have the same processor so might have different firmware.Attach-edid0003.zip
Anybody want a try?
Hello guys,
I only have a LG OLED E6 (2016) which plays some (not all) DV mp4 and TS files, but not any mkv files as Dolby Vision. I wonder if any of you knows a proper way to convert mkvs created with the latest MakeMKV, to DV .ts files (latest TSMuxer doesn't work for me, it creates a ts file that plays in HDR).
Maybe you @yusesope ?
Thanks in advance
Thanks in advance
I have a LG CX and Oppo 203 and want to know if the DV signal displayed by the LG CX is tv-led or player-led.
How can I get that info ?
Thx.
Thx.
yes, I know that. But I want to leave on AUTO and see what DV type (tv-led or player-led) it sends depending on the media it plays backDaMacFunkin wrote: ↑Sat Dec 05, 2020 6:55 amThe Oppo can be set to player led or tv led for Dolby vision in the hdr settings.
is there any way to get that info ?
Thanks for your response and for the information. I'm going to try an experiment with some files in the hope I can help narrow down/confirm the cause.PlatypusW wrote: ↑Tue Dec 01, 2020 11:59 amI believe the furtherest we have got with the seeking issue, is that it is somehow related to the length of the file.
Interestingly, different formats, whilst they don’t support DV, supposedly allow seeking to work with long duration.
I haven’t got my player yet to investigate myself, but I think that’s all we know at the moment. Duration seems to be a factor but not necessarily the only factor at play.
Can’t help with the subtitle sync issue though, maybe someone else can.
Last night I watched The Lord of the Rings The Fellowship of the Ring and I was able to fast forward. I used the latest version of tsMuxer and muxed both parts to individual m2ts files.RESET_9999 wrote: ↑Thu Dec 03, 2020 11:35 pmI'm not sure of that anymore ...
The Lord of the rings trilogy all failed to FF/RW.
same for the first 2 Hobbit.
but somehow the Hobbit 3 has no issue with FF/RW even though it's a 2h40 movie. I'm sure I had issues with title shorter than that.
I merged mine in a single TS file.
So if FF works for each individual part, that pretty much confirms the issue is related to the length of the movie.
thank you
