www.makemkv.com
MakeMKV support forum
It is currently Sun Jul 22, 2018 4:07 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4
Author Message
 Post subject: Re: A little confused
PostPosted: Thu Jan 25, 2018 12:23 pm
Offline
Got my Oppo udp 203 yesterday and it worked perfectly. I would say the MKV files are played bit for bit perfect. DTSX and Atmos play and the picture looks perfect.
Top
 Profile
PostPosted: Sat Jan 27, 2018 8:20 pm
Offline
I'm pretty happy with makemkv and bought my license today and want to give a thanks to Mike and all who help out. I updated to 1.10.10 and when to rebackup my UHD movies keeping just the one audio this time and they didn't work. I recopied the hash keys to the directory and it works now. Is that normal?
Top
 Profile
PostPosted: Sat Jan 27, 2018 9:16 pm
Offline
Make sure your data directory specified in preferences, where the hashed keys file goes, is not the same as your program directory. The program directory is cleared when you upgrade to a new version.
_________________
Using: ASUS BW-16D1HT 3.00 || UHD FAQ - If you're new to UHD, read it!
Top
 Profile
PostPosted: Sat Jan 27, 2018 9:22 pm
Offline
From just above the hashed keys download link:
"Update: please download the latest keys. Due to a bug in 1.10.9 previously released keys are not compatible with 1.10.10."
_________________
Buy MakeMKV - Latest Beta Key - Current Version (changelogs) - Old Versions - Batch Converter
Top
 Profile
PostPosted: Sat Jan 27, 2018 10:46 pm
Offline
yep that was it.
So as of now The Bourne Identity is the only one I can't back up. I emailed the dump file so I just wait for a key update?
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: BobbyDig, rivey and 14 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
