www.makemkv.com
MakeMKV support forum
It is currently Mon Jul 23, 2018 12:16 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Sun Dec 31, 2017 3:41 pm
Offline
If the moderators find posts like this more irritating than useful, I won't be offended if you delete it.
I just wanted to say that MakeMKV is awesome. I've been using it for two years. I switched my main PC, and rather than re-use my previous activation code I just bought another one as a form of thank-you. Even with DVDs, it can rip a lot of disks that HandBrake and similar tools can't manage.
Top
 Profile
PostPosted: Tue Mar 06, 2018 7:04 pm
Offline
I wholeheartedly agree! Bought the license several years ago. Thanks for your continued support!
Top
 Profile
PostPosted: Mon Mar 12, 2018 8:36 am
Offline
I would like to add a Thank You to the contributors of this forum.
Their contributions are most helpful.
For example, this is how to successfully compile makemkv with the old gcc compiler of the deprecated Ubuntu 12.04 Precise distribution.
You'll need 3 modifications to the standard procedure, otherwise compilation stops in the make process with an error 01.
1. ./configure CFLAGS='-D__STDC_CONSTANT_MACROS -D__STDC_LIMIT_MACROS'
(not sure that this is compulsory, prevents useless warnings)
2. Generated Makefile
Replace "-std=c+11" in line $(GXX) -std=c++11 $(CFLAGS) ...
with "-std=c++0x"
3. Libmkv.cpp in libmakemkv/src
Move the lines
#ifndef __STDC_FORMAT_MACROS
#define __STDC_FORMAT_MACROS 1
#endif
#include <inttypes.h>
BEFORE the other #include directives
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 9 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
