www.makemkv.com
MakeMKV support forum
It is currently Fri Jul 20, 2018 8:50 am
Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Author Message
PostPosted: Sat Jan 27, 2018 12:40 am
Offline
Mike,
What exactly is the simple fix?? I have the sg module loaded, with valid sg device for the CDROM, and yet only version prior to 1.10.9 on my Debian (arch based) system can locate the drive.
I have sg loaded, i.e.:
# lsmod | grep sg
sg 29973 0 ll /dev/sg*
scsi_mod 191405 4 sg,libata,sd_mod,sr_mo
lsscsi shows the cdrom at [2:0:0:0], i.e.:
# lsscsi -v
[0:0:0:0] disk ATA ST1000DM003-1ER1 SCOP /dev/sda
dir: /sys/bus/scsi/devices/0:0:0:0 [/sys/devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0]
[1:0:0:0] disk ATA ST1000DM003-1SB1 CC43 /dev/sdb
dir: /sys/bus/scsi/devices/1:0:0:0 [/sys/devices/pci0000:00/0000:00:1f.2/ata2/host1/target1:0:0/1:0:0:0]
[2:0:0:0] cd/dvd TSSTcorp CDDVDW SE-S204N TS02 /dev/sr0
dir: /sys/bus/scsi/devices/2:0:0:0 [/sys/devices/pci0000:00/0000:00:1f.2/ata3/host2/target2:0:0/2:0:0:0]
[3:0:0:0] disk ATA ST2000DM001-1ER1 CC26 /dev/sdc
dir: /sys/bus/scsi/devices/3:0:0:0 [/sys/devices/pci0000:00/0000:00:1f.2/ata4/host3/target3:0:0/3:0:0:0]
[4:0:0:0] disk ATA ST2000DM001-1ER1 CC26 /dev/sdd
dir: /sys/bus/scsi/devices/4:0:0:0 [/sys/devices/pci0000:00/0000:00:1f.2/ata5/host4/target4:0:0/4:0:0:0]
[5:0:0:0] disk ATA ST1000DM003-1SB1 CC43 /dev/sde
dir: /sys/bus/scsi/devices/5:0:0:0 [/sys/devices/pci0000:00/0000:00:1f.2/ata6/host5/target5:0:0/5:0:0:0]
I have /dev/sg2 populated for the cdrom, i.e.:
# ll /dev/sg*
crw-rw---- 1 root disk 21, 0 Jan 24 19:55 /dev/sg0
crw-rw---- 1 root disk 21, 1 Jan 24 19:55 /dev/sg1
crw-rw----+ 1 root cdrom 21, 2 Jan 24 19:55 /dev/sg2
crw-rw---- 1 root disk 21, 3 Jan 24 19:55 /dev/sg3
crw-rw---- 1 root disk 21, 4 Jan 24 19:55 /dev/sg4
crw-rw---- 1 root disk 21, 5 Jan 24 19:55 /dev/sg5
I have /dev/sr0 populated for cdrom, i.e.:
# ll /dev/sr*
brw-rw----+ 1 root cdrom 11, 0 Jan 24 19:55 /dev/sr0
sg_map shows /dev/sg2 mapped to /dev/sr0 and they are on [2.0.0.0], i.e.:
# sg_map -sr -x
/dev/sg0 0 0 0 0 0
/dev/sg1 1 0 0 0 0
/dev/sg2 2 0 0 0 5 /dev/sr0
/dev/sg3 3 0 0 0 0
/dev/sg4 4 0 0 0 0
/dev/sg5 5 0 0 0 0
I have /sys/bus/scsi/devices populated, i.e.:
# ls -la /sys/bus/scsi/devices/
total 0
drwxr-xr-x 2 root root 0 Jan 26 16:22 .
drwxr-xr-x 4 root root 0 Jan 26 16:22 ..
lrwxrwxrwx 1 root root 0 Jan 26 16:22 0:0:0:0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0
lrwxrwxrwx 1 root root 0 Jan 26 16:22 1:0:0:0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata2/host1/target1:0:0/1:0:0:0
lrwxrwxrwx 1 root root 0 Jan 26 16:22 2:0:0:0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata3/host2/target2:0:0/2:0:0:0
lrwxrwxrwx 1 root root 0 Jan 26 16:22 3:0:0:0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata4/host3/target3:0:0/3:0:0:0
lrwxrwxrwx 1 root root 0 Jan 26 16:22 4:0:0:0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata5/host4/target4:0:0/4:0:0:0
lrwxrwxrwx 1 root root 0 Jan 26 16:22 5:0:0:0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata6/host5/target5:0:0/5:0:0:0
lrwxrwxrwx 1 root root 0 Jan 26 16:22 host0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata1/host0
lrwxrwxrwx 1 root root 0 Jan 26 16:22 host1 -> ../../../devices/pci0000:00/0000:00:1f.2/ata2/host1
lrwxrwxrwx 1 root root 0 Jan 26 16:22 host2 -> ../../../devices/pci0000:00/0000:00:1f.2/ata3/host2
lrwxrwxrwx 1 root root 0 Jan 26 16:22 host3 -> ../../../devices/pci0000:00/0000:00:1f.2/ata4/host3
lrwxrwxrwx 1 root root 0 Jan 26 16:22 host4 -> ../../../devices/pci0000:00/0000:00:1f.2/ata5/host4
lrwxrwxrwx 1 root root 0 Jan 26 16:22 host5 -> ../../../devices/pci0000:00/0000:00:1f.2/ata6/host5
lrwxrwxrwx 1 root root 0 Jan 26 16:22 target0:0:0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0
lrwxrwxrwx 1 root root 0 Jan 26 16:22 target1:0:0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata2/host1/target1:0:0
lrwxrwxrwx 1 root root 0 Jan 26 16:22 target2:0:0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata3/host2/target2:0:0
lrwxrwxrwx 1 root root 0 Jan 26 16:22 target3:0:0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata4/host3/target3:0:0
lrwxrwxrwx 1 root root 0 Jan 26 16:22 target4:0:0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata5/host4/target4:0:0
lrwxrwxrwx 1 root root 0 Jan 26 16:22 target5:0:0 -> ../../../devices/pci0000:00/0000:00:1f.2/ata6/host5/target5:0:0
Please advise.
Top
 Profile
PostPosted: Sat Jan 27, 2018 1:12 pm
Offline
This issue also is present with arch based distros.
Linux version 4.14.14-1-MANJARO (builduser@manjaro) (gcc version 7.2.1 20171224 (GCC)) #1 SMP PREEMPT Wed Jan 17 22:34:54 UTC 2018
However I can confirm that
sudo modprobe sg
fixes this issue.
Top
 Profile
PostPosted: Sat Jan 27, 2018 4:50 pm
Offline
basti0001,
If you look at my output, you will see that I indeed already have the sg module loaded. So in my arch case the sg module is NOT the issue.
Best Regards
Top
 Profile
PostPosted: Sun Jan 28, 2018 8:31 am
Offline
While I'm not a complete Linux noob, I am not versed at the level of detail into the operating system to have been messing with modules before.
From what I can read online, newer versions of Ubuntu had the sg module internal as opposed to a loadable module. When I ls -la /dev/sg* and ls -la /dev/sr*, I get the following:
Code:
ls -la /dev/sg*
crw-rw----  1 root disk  21, 0 Dec  4 22:53 /dev/sg0
crw-rw----  1 root disk  21, 1 Dec  4 22:53 /dev/sg1
crw-rw----  1 root disk  21, 2 Dec  4 22:53 /dev/sg2
crw-rw----  1 root disk  21, 3 Dec  4 22:53 /dev/sg3
crw-rw----  1 root disk  21, 4 Dec  4 22:53 /dev/sg4
crw-rw----  1 root disk  21, 5 Dec  4 22:53 /dev/sg5
crw-rw----  1 root disk  21, 6 Dec  4 22:53 /dev/sg6
crw-rw----+ 1 root cdrom 21, 7 Dec  4 22:53 /dev/sg7
crw-rw----  1 root disk  21, 8 Dec  4 22:53 /dev/sg8
and
Code:
brw-rw----+ 1 root cdrom 11, 0 Jan 28 03:01 /dev/sr0
Now, if I've figured this correctly and am reading the above right, /dev/sg7 and /dev/sr0 both are pointing to my DVD drive... however, I am still not able to get to the DVD in the newest version of MakeMKV.
I would appreciate some more help, and please remember that I'm a fair noob and probably need some pretty basic instructions... it took me 45 minutes of searching on Google (thanks to the reams of pages about modules and how common the phrase is) to find how to add module... and while looking for that, I found the site that claims that sg is no longer needed on Ubuntu... and I followed instructions on that page to do:
Code:
find /lib/modules/`uname -r` -type f -name "*.ko" | grep sg
and found no existing sg.ko file...
So, if it's internal, then I should be working and if it's not, I cannot load it because the file doesn't exist... so where can I download it?
Thank you,
Top
 Profile
PostPosted: Sun Jan 28, 2018 4:55 pm
Offline
Code:
ls -la /dev/sg*
and
Code:
Code:
Thank you,
I can echo everything that JokerJim said above for my Ubuntu 14.04.5, including my noob status.
I did find the module here: http://sg.danny.cz/sg/#mozTocId689512 . However, after downloading it I discovered that it won't install:
Code:
sudo insmod sg.c
insmod: ERROR: could not insert module sg.c: Invalid module format
I have also heard that sg is no longer needed yet, as JokerJim, 'ls -la /dev/sg*' lsts all my drives, including my two optical drives, and I get the same list wth 'lsscsi -g.' And 'sudo modprobe sg' returns nothing, not even an error message.
Top
 Profile
PostPosted: Sun Jan 28, 2018 6:31 pm
Offline
Hey mike admin,
Can you give specific instructions on your simple fix??
Top
 Profile
PostPosted: Sun Jan 28, 2018 9:00 pm
Offline
# lsscsi -v
Could you please do
Code:
ls -laR /sys/bus/scsi/devices/2:0:0:0/
hexdump -C /sys/bus/scsi/devices/2:0:0:0/inquiry
Top
 Profile
PostPosted: Sun Jan 28, 2018 10:24 pm
Offline
Hey Mike,
You bet:
# ls -laR /sys/bus/scsi/devices/2:0:0:0/
/sys/bus/scsi/devices/2:0:0:0/:
total 0
drwxr-xr-x 7 root root 0 Jan 28 14:21 .
drwxr-xr-x 4 root root 0 Jan 27 21:23 ..
drwxr-xr-x 3 root root 0 Jan 27 21:23 block
drwxr-xr-x 3 root root 0 Jan 27 21:23 bsg
--w------- 1 root root 4096 Jan 28 14:21 delete
-r--r--r-- 1 root root 4096 Jan 28 14:21 device_blocked
-r--r--r-- 1 root root 4096 Jan 28 14:21 device_busy
lrwxrwxrwx 1 root root 0 Jan 27 21:24 driver -> ../../../../../../../bus/scsi/drivers/sr
-rw-r--r-- 1 root root 4096 Jan 28 14:21 eh_timeout
-r--r--r-- 1 root root 4096 Jan 28 14:21 evt_capacity_change_reported
-r--r--r-- 1 root root 4096 Jan 28 14:21 evt_inquiry_change_reported
-r--r--r-- 1 root root 4096 Jan 28 14:21 evt_lun_change_reported
-r--r--r-- 1 root root 4096 Jan 28 14:21 evt_media_change
-r--r--r-- 1 root root 4096 Jan 28 14:21 evt_mode_parameter_change_reported
-r--r--r-- 1 root root 4096 Jan 28 14:21 evt_soft_threshold_reached
lrwxrwxrwx 1 root root 0 Jan 28 14:21 generic -> scsi_generic/sg2
-r--r--r-- 1 root root 4096 Jan 28 14:21 iocounterbits
-r--r--r-- 1 root root 4096 Jan 28 14:21 iodone_cnt
-r--r--r-- 1 root root 4096 Jan 28 14:21 ioerr_cnt
-r--r--r-- 1 root root 4096 Jan 28 14:21 iorequest_cnt
-r--r--r-- 1 root root 4096 Jan 28 14:21 modalias
-r--r--r-- 1 root root 4096 Jan 27 21:24 model
drwxr-xr-x 2 root root 0 Jan 28 14:21 power
-rw-r--r-- 1 root root 4096 Jan 28 14:21 queue_depth
-rw-r--r-- 1 root root 4096 Jan 28 14:21 queue_ramp_up_period
-rw-r--r-- 1 root root 4096 Jan 28 14:21 queue_type
--w------- 1 root root 4096 Jan 28 14:21 rescan
-r--r--r-- 1 root root 4096 Jan 28 14:21 rev
drwxr-xr-x 3 root root 0 Jan 27 21:23 scsi_device
drwxr-xr-x 3 root root 0 Jan 27 21:23 scsi_generic
-r--r--r-- 1 root root 4096 Jan 27 21:23 scsi_level
-rw-r--r-- 1 root root 4096 Jan 28 14:21 state
lrwxrwxrwx 1 root root 0 Jan 27 21:23 subsystem -> ../../../../../../../bus/scsi
-rw-r--r-- 1 root root 4096 Jan 28 14:21 sw_activity
-rw-r--r-- 1 root root 4096 Jan 28 14:21 timeout
-r--r--r-- 1 root root 4096 Jan 27 21:23 type
-rw-r--r-- 1 root root 4096 Jan 27 21:23 uevent
-rw-r--r-- 1 root root 4096 Jan 28 14:21 unload_heads
-r--r--r-- 1 root root 4096 Jan 27 21:23 vendor
-r--r--r-- 1 root root 0 Jan 28 14:21 vpd_pg80
-r--r--r-- 1 root root 0 Jan 28 14:21 vpd_pg83
/sys/bus/scsi/devices/2:0:0:0/block:
total 0
drwxr-xr-x 3 root root 0 Jan 28 14:21 .
drwxr-xr-x 7 root root 0 Jan 28 14:21 ..
drwxr-xr-x 7 root root 0 Jan 27 21:23 sr0
/sys/bus/scsi/devices/2:0:0:0/block/sr0:
total 0
drwxr-xr-x 3 root root 0 Jan 28 14:21 ..
-r--r--r-- 1 root root 4096 Jan 28 14:21 alignment_offset
lrwxrwxrwx 1 root root 0 Jan 28 14:21 bdi -> ../../../../../../../../virtual/bdi/11:0
-r--r--r-- 1 root root 4096 Jan 28 14:21 capability
-r--r--r-- 1 root root 4096 Jan 27 21:24 dev
lrwxrwxrwx 1 root root 0 Jan 27 21:26 device -> ../../../2:0:0:0
-r--r--r-- 1 root root 4096 Jan 28 14:21 discard_alignment
-r--r--r-- 1 root root 4096 Jan 28 14:21 events
-r--r--r-- 1 root root 4096 Jan 28 14:21 events_async
-rw-r--r-- 1 root root 4096 Jan 27 21:23 events_poll_msecs
-r--r--r-- 1 root root 4096 Jan 28 14:21 ext_range
drwxr-xr-x 2 root root 0 Jan 28 14:21 holders
-r--r--r-- 1 root root 4096 Jan 28 14:21 inflight
drwxr-xr-x 3 root root 0 Jan 27 21:25 queue
-r--r--r-- 1 root root 4096 Jan 28 14:21 range
-r--r--r-- 1 root root 4096 Jan 27 21:23 removable
-r--r--r-- 1 root root 4096 Jan 27 21:25 ro
-r--r--r-- 1 root root 4096 Jan 28 14:21 size
drwxr-xr-x 2 root root 0 Jan 28 14:21 slaves
-r--r--r-- 1 root root 4096 Jan 27 21:26 stat
lrwxrwxrwx 1 root root 0 Jan 27 21:24 subsystem -> ../../../../../../../../../class/block
drwxr-xr-x 2 root root 0 Jan 28 14:21 trace
/sys/bus/scsi/devices/2:0:0:0/block/sr0/holders:
total 0
drwxr-xr-x 2 root root 0 Jan 28 14:21 .
/sys/bus/scsi/devices/2:0:0:0/block/sr0/power:
total 0
-rw-r--r-- 1 root root 4096 Jan 28 14:21 async
-rw-r--r-- 1 root root 4096 Jan 28 14:21 autosuspend_delay_ms
-rw-r--r-- 1 root root 4096 Jan 28 14:21 control
-r--r--r-- 1 root root 4096 Jan 28 14:21 runtime_active_kids
-r--r--r-- 1 root root 4096 Jan 28 14:21 runtime_active_time
-r--r--r-- 1 root root 4096 Jan 28 14:21 runtime_enabled
-r--r--r-- 1 root root 4096 Jan 28 14:21 runtime_status
-r--r--r-- 1 root root 4096 Jan 28 14:21 runtime_suspended_time
-r--r--r-- 1 root root 4096 Jan 28 14:21 runtime_usage
/sys/bus/scsi/devices/2:0:0:0/block/sr0/queue:
total 0
-rw-r--r-- 1 root root 4096 Jan 28 14:21 add_random
-r--r--r-- 1 root root 4096 Jan 28 14:21 discard_granularity
-r--r--r-- 1 root root 4096 Jan 28 14:21 discard_max_bytes
-r--r--r-- 1 root root 4096 Jan 28 14:21 discard_zeroes_data
-r--r--r-- 1 root root 4096 Jan 28 14:21 hw_sector_size
drwxr-xr-x 2 root root 0 Jan 28 14:21 iosched
-rw-r--r-- 1 root root 4096 Jan 28 14:21 iostats
-r--r--r-- 1 root root 4096 Jan 28 14:21 logical_block_size
-r--r--r-- 1 root root 4096 Jan 28 14:21 max_hw_sectors_kb
-r--r--r-- 1 root root 4096 Jan 28 14:21 max_integrity_segments
-rw-r--r-- 1 root root 4096 Jan 28 14:21 max_sectors_kb
-r--r--r-- 1 root root 4096 Jan 28 14:21 max_segments
-r--r--r-- 1 root root 4096 Jan 28 14:21 max_segment_size
-r--r--r-- 1 root root 4096 Jan 28 14:21 minimum_io_size
-rw-r--r-- 1 root root 4096 Jan 28 14:21 nomerges
-rw-r--r-- 1 root root 4096 Jan 28 14:21 nr_requests
-r--r--r-- 1 root root 4096 Jan 28 14:21 optimal_io_size
-r--r--r-- 1 root root 4096 Jan 28 14:21 physical_block_size
-rw-r--r-- 1 root root 4096 Jan 28 14:21 read_ahead_kb
-rw-r--r-- 1 root root 4096 Jan 27 21:25 rotational
-rw-r--r-- 1 root root 4096 Jan 28 14:21 rq_affinity
-rw-r--r-- 1 root root 4096 Jan 28 14:21 scheduler
-r--r--r-- 1 root root 4096 Jan 28 14:21 write_same_max_bytes
/sys/bus/scsi/devices/2:0:0:0/block/sr0/queue/iosched:
total 0
-rw-r--r-- 1 root root 4096 Jan 28 14:21 back_seek_max
-rw-r--r-- 1 root root 4096 Jan 28 14:21 back_seek_penalty
-rw-r--r-- 1 root root 4096 Jan 28 14:21 fifo_expire_async
-rw-r--r-- 1 root root 4096 Jan 28 14:21 fifo_expire_sync
-rw-r--r-- 1 root root 4096 Jan 28 14:21 group_idle
-rw-r--r-- 1 root root 4096 Jan 28 14:21 low_latency
-rw-r--r-- 1 root root 4096 Jan 28 14:21 quantum
-rw-r--r-- 1 root root 4096 Jan 28 14:21 slice_async
-rw-r--r-- 1 root root 4096 Jan 28 14:21 slice_async_rq
-rw-r--r-- 1 root root 4096 Jan 28 14:21 slice_idle
-rw-r--r-- 1 root root 4096 Jan 28 14:21 slice_sync
-rw-r--r-- 1 root root 4096 Jan 28 14:21 target_latency
/sys/bus/scsi/devices/2:0:0:0/block/sr0/slaves:
total 0
/sys/bus/scsi/devices/2:0:0:0/block/sr0/trace:
total 0
-rw-r--r-- 1 root root 4096 Jan 28 14:21 act_mask
-rw-r--r-- 1 root root 4096 Jan 28 14:21 enable
-rw-r--r-- 1 root root 4096 Jan 28 14:21 end_lba
-rw-r--r-- 1 root root 4096 Jan 28 14:21 pid
-rw-r--r-- 1 root root 4096 Jan 28 14:21 start_lba
/sys/bus/scsi/devices/2:0:0:0/bsg:
total 0
drwxr-xr-x 3 root root 0 Jan 27 21:23 2:0:0:0
/sys/bus/scsi/devices/2:0:0:0/bsg/2:0:0:0:
total 0
lrwxrwxrwx 1 root root 0 Jan 28 14:21 device -> ../../../2:0:0:0
lrwxrwxrwx 1 root root 0 Jan 27 21:25 subsystem -> ../../../../../../../../../class/bsg
/sys/bus/scsi/devices/2:0:0:0/bsg/2:0:0:0/power:
total 0
/sys/bus/scsi/devices/2:0:0:0/power:
total 0
/sys/bus/scsi/devices/2:0:0:0/scsi_device:
total 0
/sys/bus/scsi/devices/2:0:0:0/scsi_device/2:0:0:0:
total 0
lrwxrwxrwx 1 root root 0 Jan 27 21:25 subsystem -> ../../../../../../../../../class/scsi_device
/sys/bus/scsi/devices/2:0:0:0/scsi_device/2:0:0:0/power:
total 0
/sys/bus/scsi/devices/2:0:0:0/scsi_generic:
total 0
drwxr-xr-x 3 root root 0 Jan 27 21:23 sg2
/sys/bus/scsi/devices/2:0:0:0/scsi_generic/sg2:
total 0
lrwxrwxrwx 1 root root 0 Jan 27 21:24 subsystem -> ../../../../../../../../../class/scsi_generic
/sys/bus/scsi/devices/2:0:0:0/scsi_generic/sg2/power:
total 0
# hexdump -C /sys/bus/scsi/devices/2:0:0:0/inquiry
hexdump: /sys/bus/scsi/devices/2:0:0:0/inquiry: No such file or directory
Top
 Profile
PostPosted: Mon Jan 29, 2018 4:01 pm
Offline
Ubuntu 14.04.5. I get the same results as nickjpg, including the failure of # hexdump -C /sys/bus/scsi/devices/2:0:0:0/inquiry.
Top
 Profile
PostPosted: Wed Jan 31, 2018 11:42 pm
Offline
i'm at a loss here too. i've tried everything posted in this thread.
i'm on unraid 6.3.5.
can you take a look, mike?
Code:
root@Tower:~# ls -la /dev/sg*
crw-rw---- 1 root cdrom 21, 3 Jan 31 06:56 /dev/sg3
Code:
root@Tower:~# ls -la /dev/sr*
brw-rw---- 1 root cdrom 11, 0 Jan 31 06:56 /dev/sr0
i can't tell if the sg driver's loaded or not. /sys/module/sg/ is present though.
Code:
root@Tower:~# sudo modprobe sg
root@Tower:~#
root@Tower:~# sg_map -sr -x
-bash: sg_map: command not found
Code:
root@Tower:~# lsscsi -g
[6:0:0:0]    cd/dvd  HL-DT-ST BDDVDRW UH12NS30 1.03  /dev/sr0   /dev/sg3
Code:
root@Tower:~# lsscsi -v
  dir: /sys/bus/scsi/devices/6:0:0:0  [/sys/devices/pci0000:00/0000:00:1f.2/ata4/host6/target6:0:0/6:0:0:0]
Code:
root@Tower:~# hexdump -C /sys/bus/scsi/devices/6:0:0:0/inquiry
00000000  05 80 05 32 5b 00 00 00  48 4c 2d 44 54 2d 53 54  |...2[...HL-DT-ST|
00000010  42 44 44 56 44 52 57 20  55 48 31 32 4e 53 33 30  |BDDVDRW UH12NS30|
00000020  31 2e 30 33 4e 30 41 30  35 41 30 4b 39 46 47 33  |1.03N0A05A0K9FG3|
00000030  38 46 32 34 33 31 20 20  00 00 00 00 00 00 00 00  |8F2431  ........|
00000040  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
Code:
root@Tower:~# ls -laR /sys/bus/scsi/devices/6:0:0:0/
/sys/bus/scsi/devices/6\:0\:0\:0/:
total 0
drwxr-xr-x 7 root root    0 Jan 31 06:55 ./
drwxr-xr-x 4 root root    0 Jan 31 06:55 ../
drwxr-xr-x 3 root root    0 Jan 31 06:55 block/
drwxr-xr-x 3 root root    0 Jan 31 06:55 bsg/
--w------- 1 root root 4096 Jan 31 14:49 delete
-r--r--r-- 1 root root 4096 Jan 31 14:49 device_blocked
-r--r--r-- 1 root root 4096 Jan 31 14:49 device_busy
lrwxrwxrwx 1 root root    0 Jan 31 14:49 driver -> ../../../../../../../bus/scsi/drivers/sr/
-rw-r--r-- 1 root root 4096 Jan 31 14:49 eh_timeout
-r--r--r-- 1 root root 4096 Jan 31 14:49 evt_capacity_change_reported
-r--r--r-- 1 root root 4096 Jan 31 14:49 evt_inquiry_change_reported
-r--r--r-- 1 root root 4096 Jan 31 14:49 evt_lun_change_reported
-r--r--r-- 1 root root 4096 Jan 31 14:49 evt_media_change
-r--r--r-- 1 root root 4096 Jan 31 14:49 evt_mode_parameter_change_reported
-r--r--r-- 1 root root 4096 Jan 31 14:49 evt_soft_threshold_reached
lrwxrwxrwx 1 root root    0 Jan 31 14:49 generic -> scsi_generic/sg3/
-r--r--r-- 1 root root    0 Jan 31 14:49 inquiry
-r--r--r-- 1 root root 4096 Jan 31 14:49 iocounterbits
-r--r--r-- 1 root root 4096 Jan 31 14:49 iodone_cnt
-r--r--r-- 1 root root 4096 Jan 31 14:49 ioerr_cnt
-r--r--r-- 1 root root 4096 Jan 31 14:49 iorequest_cnt
-r--r--r-- 1 root root 4096 Jan 31 14:49 modalias
-r--r--r-- 1 root root 4096 Jan 31 14:49 model
drwxr-xr-x 2 root root    0 Jan 31 11:26 power/
-rw-r--r-- 1 root root 4096 Jan 31 14:49 queue_depth
-rw-r--r-- 1 root root 4096 Jan 31 14:49 queue_ramp_up_period
-rw-r--r-- 1 root root 4096 Jan 31 14:49 queue_type
--w------- 1 root root 4096 Jan 31 14:49 rescan
-r--r--r-- 1 root root 4096 Jan 31 14:49 rev
drwxr-xr-x 3 root root    0 Jan 31 06:55 scsi_device/
drwxr-xr-x 3 root root    0 Jan 31 06:55 scsi_generic/
-r--r--r-- 1 root root 4096 Jan 31 14:49 scsi_level
-rw-r--r-- 1 root root 4096 Jan 31 14:49 state
lrwxrwxrwx 1 root root    0 Jan 31 06:55 subsystem -> ../../../../../../../bus/scsi/
-rw-r--r-- 1 root root 4096 Jan 31 14:49 sw_activity
-rw-r--r-- 1 root root 4096 Jan 31 14:49 timeout
-r--r--r-- 1 root root 4096 Jan 31 14:49 type
-rw-r--r-- 1 root root 4096 Jan 31 14:49 uevent
-rw-r--r-- 1 root root 4096 Jan 31 14:49 unload_heads
-r--r--r-- 1 root root 4096 Jan 31 14:49 vendor
-r--r--r-- 1 root root 4096 Jan 31 14:49 wwid
/sys/bus/scsi/devices/6\:0\:0\:0/block:
total 0
drwxr-xr-x 3 root root 0 Jan 31 06:55 ./
drwxr-xr-x 7 root root 0 Jan 31 06:55 ../
drwxr-xr-x 7 root root 0 Jan 31 06:55 sr0/
/sys/bus/scsi/devices/6\:0\:0\:0/block/sr0:
total 0
drwxr-xr-x 3 root root    0 Jan 31 06:55 ../
-r--r--r-- 1 root root 4096 Jan 31 14:49 alignment_offset
-rw-r--r-- 1 root root 4096 Jan 31 14:49 badblocks
lrwxrwxrwx 1 root root    0 Jan 31 14:49 bdi -> ../../../../../../../../virtual/bdi/11:0/
-r--r--r-- 1 root root 4096 Jan 31 14:49 capability
lrwxrwxrwx 1 root root    0 Jan 31 06:56 device -> ../../../6:0:0:0/
-r--r--r-- 1 root root 4096 Jan 31 14:49 discard_alignment
-r--r--r-- 1 root root 4096 Jan 31 14:49 events
-r--r--r-- 1 root root 4096 Jan 31 14:49 events_async
-rw-r--r-- 1 root root 4096 Jan 31 14:49 events_poll_msecs
-r--r--r-- 1 root root 4096 Jan 31 14:49 ext_range
drwxr-xr-x 2 root root    0 Jan 31 06:56 holders/
-r--r--r-- 1 root root 4096 Jan 31 14:49 inflight
drwxr-xr-x 2 root root    0 Jan 31 11:26 integrity/
drwxr-xr-x 3 root root    0 Jan 31 06:55 queue/
-r--r--r-- 1 root root 4096 Jan 31 14:49 range
-r--r--r-- 1 root root 4096 Jan 31 14:49 removable
-r--r--r-- 1 root root 4096 Jan 31 14:49 ro
-r--r--r-- 1 root root 4096 Jan 31 14:49 size
drwxr-xr-x 2 root root    0 Jan 31 06:56 slaves/
-r--r--r-- 1 root root 4096 Jan 31 14:49 stat
lrwxrwxrwx 1 root root    0 Jan 31 06:56 subsystem -> ../../../../../../../../../class/block/
-rw-r--r-- 1 root root 4096 Jan 31 06:56 uevent
/sys/bus/scsi/devices/6\:0\:0\:0/block/sr0/holders:
total 0
drwxr-xr-x 2 root root 0 Jan 31 06:56 ./
/sys/bus/scsi/devices/6\:0\:0\:0/block/sr0/integrity:
total 0
drwxr-xr-x 2 root root    0 Jan 31 11:26 ./
-r--r--r-- 1 root root 4096 Jan 31 14:49 device_is_integrity_capable
-r--r--r-- 1 root root 4096 Jan 31 14:49 format
-r--r--r-- 1 root root 4096 Jan 31 14:49 protection_interval_bytes
-rw-r--r-- 1 root root 4096 Jan 31 14:49 read_verify
-r--r--r-- 1 root root 4096 Jan 31 14:49 tag_size
-rw-r--r-- 1 root root 4096 Jan 31 14:49 write_generate
/sys/bus/scsi/devices/6\:0\:0\:0/block/sr0/power:
total 0
-rw-r--r-- 1 root root 4096 Jan 31 14:49 autosuspend_delay_ms
-rw-r--r-- 1 root root 4096 Jan 31 14:49 control
-r--r--r-- 1 root root 4096 Jan 31 14:49 runtime_active_time
-r--r--r-- 1 root root 4096 Jan 31 14:49 runtime_status
-r--r--r-- 1 root root 4096 Jan 31 14:49 runtime_suspended_time
/sys/bus/scsi/devices/6\:0\:0\:0/block/sr0/queue:
total 0
-rw-r--r-- 1 root root 4096 Jan 31 14:49 add_random
lrwxrwxrwx 1 root root    0 Jan 31 14:49 bsg -> ../../../bsg/6:0:0:0/
-r--r--r-- 1 root root 4096 Jan 31 14:49 dax
-r--r--r-- 1 root root 4096 Jan 31 14:49 discard_granularity
-rw-r--r-- 1 root root 4096 Jan 31 14:49 discard_max_bytes
-r--r--r-- 1 root root 4096 Jan 31 14:49 discard_max_hw_bytes
-r--r--r-- 1 root root 4096 Jan 31 14:49 discard_zeroes_data
-r--r--r-- 1 root root 4096 Jan 31 14:49 hw_sector_size
-rw-r--r-- 1 root root 4096 Jan 31 14:49 io_poll
drwxr-xr-x 2 root root    0 Jan 31 11:26 iosched/
-rw-r--r-- 1 root root 4096 Jan 31 14:49 iostats
-r--r--r-- 1 root root 4096 Jan 31 14:49 logical_block_size
-r--r--r-- 1 root root 4096 Jan 31 14:49 max_hw_sectors_kb
-r--r--r-- 1 root root 4096 Jan 31 14:49 max_integrity_segments
-rw-r--r-- 1 root root 4096 Jan 31 14:49 max_sectors_kb
-r--r--r-- 1 root root 4096 Jan 31 14:49 max_segment_size
-r--r--r-- 1 root root 4096 Jan 31 14:49 max_segments
-r--r--r-- 1 root root 4096 Jan 31 14:49 minimum_io_size
-rw-r--r-- 1 root root 4096 Jan 31 14:49 nomerges
-rw-r--r-- 1 root root 4096 Jan 31 14:49 nr_requests
-r--r--r-- 1 root root 4096 Jan 31 14:49 optimal_io_size
-r--r--r-- 1 root root 4096 Jan 31 14:49 physical_block_size
-rw-r--r-- 1 root root 4096 Jan 31 14:49 read_ahead_kb
-rw-r--r-- 1 root root 4096 Jan 31 14:49 rotational
-rw-r--r-- 1 root root 4096 Jan 31 14:49 rq_affinity
-rw-r--r-- 1 root root 4096 Jan 31 14:49 scheduler
-rw-r--r-- 1 root root 4096 Jan 31 14:49 write_cache
-r--r--r-- 1 root root 4096 Jan 31 14:49 write_same_max_bytes
/sys/bus/scsi/devices/6\:0\:0\:0/block/sr0/queue/iosched:
total 0
/sys/bus/scsi/devices/6\:0\:0\:0/block/sr0/slaves:
total 0
/sys/bus/scsi/devices/6\:0\:0\:0/bsg:
total 0
drwxr-xr-x 3 root root 0 Jan 31 06:55 6:0:0:0/
/sys/bus/scsi/devices/6\:0\:0\:0/bsg/6\:0\:0\:0:
total 0
lrwxrwxrwx 1 root root    0 Jan 31 14:49 device -> ../../../6:0:0:0/
lrwxrwxrwx 1 root root    0 Jan 31 06:54 subsystem -> ../../../../../../../../../class/bsg/
/sys/bus/scsi/devices/6\:0\:0\:0/bsg/6\:0\:0\:0/power:
total 0
/sys/bus/scsi/devices/6\:0\:0\:0/power:
total 0
/sys/bus/scsi/devices/6\:0\:0\:0/scsi_device:
total 0
/sys/bus/scsi/devices/6\:0\:0\:0/scsi_device/6\:0\:0\:0:
total 0
lrwxrwxrwx 1 root root    0 Jan 31 06:54 subsystem -> ../../../../../../../../../class/scsi_device/
/sys/bus/scsi/devices/6\:0\:0\:0/scsi_device/6\:0\:0\:0/power:
total 0
/sys/bus/scsi/devices/6\:0\:0\:0/scsi_generic:
total 0
drwxr-xr-x 3 root root 0 Jan 31 06:55 sg3/
/sys/bus/scsi/devices/6\:0\:0\:0/scsi_generic/sg3:
total 0
lrwxrwxrwx 1 root root    0 Jan 31 06:54 subsystem -> ../../../../../../../../../class/scsi_generic/
/sys/bus/scsi/devices/6\:0\:0\:0/scsi_generic/sg3/power:
total 0
Top
 Profile
PostPosted: Thu Feb 01, 2018 10:41 am
Offline
Are you running MakeMKV inside a docker container? If yes, then I recommend that you post your issue on the support thread (unRAID forum) of the container . An incorrect container configuration can prevent the detection.
Top
 Profile
PostPosted: Fri Feb 02, 2018 4:20 pm
Offline
I installed 1.10.10 on my Lint(rebecca) system and it worked like a charm. I installed back in October 2017, ripped a few Blu-Rays and a few DVDs. Haven't used it since. Now I get the "cannot find any usable drives" error. I reinstalled after removing the old version with the Software Manager not sure of which version I had previously installed, then reinstalled version 1.10.10. Same error, and I realized that I had 1.10.10 installed back in October 2017.
What I didn't do is enter the beta key since I was planning on purchasing a license at some point. A key difference in my current reinstalled version in the lack of the MakeMKV icon in the system launcher. It seems that having not entered the beta key or purchasing one, more than 60 days has gone by, but now I'm stuck? I have
now entered the beta key, restarted, no change.
The preferences menu is available.
I really would prefer to purchase a license for my Linux system as oppose to my iMac. Can't trust Apple won't muck it up. I don't have any Windows systems.
Probably time to just give up any stop using computers altogether. Oh well.
Top
 Profile
PostPosted: Fri Feb 02, 2018 5:17 pm
Offline
MakeMKV's license is applicable to all three.
_________________
How to aid in finding the answer to your problem: http://www.makemkv.com/faq/item/8
Top
 Profile
PostPosted: Fri Feb 02, 2018 5:57 pm
Offline
I’ve used a licensed version on my Mac for almost 5 years with zero issues.
Top
 Profile
PostPosted: Fri Feb 02, 2018 9:27 pm
Offline
Still waiting for "mike admin" to provide detailed instructions on his "simple fix".
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 8 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
