www.makemkv.com
MakeMKV support forum
It is currently Mon Jul 23, 2018 6:12 am
Post new topic Reply to topic  [ 7 posts ]
Author Message
PostPosted: Sat May 12, 2018 12:20 pm
Offline
Had it building fine on Fedora 27 w/ GCC 7 but now I get this:
Code:
libffabi/src/ffabi.c: In function 'ffm_audio_encode_init':
libffabi/src/ffabi.c:520:30: error: 'CODEC_FLAG_GLOBAL_HEADER' undeclared (first use in this function); did you mean 'AV_CODEC_FLAG_GLOBAL_HEADER'?
         ctx->avctx->flags |= CODEC_FLAG_GLOBAL_HEADER;
libffabi/src/ffabi.c:520:30: note: each undeclared identifier is reported only once for each function it appears in
libffabi/src/ffabi.c: In function 'ffm_audio_encode_get_info':
libffabi/src/ffabi.c:721:28: error: 'CODEC_FLAG_GLOBAL_HEADER' undeclared (first use in this function); did you mean 'AV_CODEC_FLAG_GLOBAL_HEADER'?
     if ((ctx->avctx->flags&CODEC_FLAG_GLOBAL_HEADER)!=0)
Thanks,
Richard
Top
 Profile
PostPosted: Sun May 13, 2018 2:14 pm
Offline
The problem isn't GCC, it's that libavformat just updated and a variable name changed. Here's a diff:
Code:
*** makemkv-oss-1.12.2/libffabi/src/ffabi.c.ORIG   2018-04-27 20:53:47.000000000 -0500
--- makemkv-oss-1.12.2/libffabi/src/ffabi.c   2018-05-13 09:11:26.215809333 -0500
*** 517,523 ****
          info->profile : FF_PROFILE_UNKNOWN;
      if ((CodecFlags&FFM_CODEC_FLAG_GLOBAL_HEADER)!=0)
!         ctx->avctx->flags |= CODEC_FLAG_GLOBAL_HEADER;
      if (argp) {
          for (i=0;argp[i];i+=2) {
--- 517,523 ----
!         ctx->avctx->flags |= AV_CODEC_FLAG_GLOBAL_HEADER;
      if (argp) {
*** 718,724 ****
      info->delay = (int32_t)ctx->avctx->delay;
      info->flags = 0;
!     if ((ctx->avctx->flags&CODEC_FLAG_GLOBAL_HEADER)!=0)
          info->flags |= FFM_CODEC_FLAG_GLOBAL_HEADER;
      return 0;
--- 718,724 ----
      info->flags = 0;
!     if ((ctx->avctx->flags&AV_CODEC_FLAG_GLOBAL_HEADER)!=0)
      return 0;
Apply that and it should compile okay.
Top
 Profile
PostPosted: Mon May 14, 2018 1:48 am
Offline
The patch allows it to compile, but I get an error "Application failed to initialize" when I try and launch it.
Top
 Profile
PostPosted: Tue May 15, 2018 4:28 am
Offline
I reinstalled Fedora 28 from scratch. That helped a lot. The series of upgrades left a bunch of cruft that made compiles not work correctly. (Like ldconfig database containing old information that no longer existed.)
Top
 Profile
PostPosted: Sat May 19, 2018 3:32 am
Offline
This looks to be due to an upgrade to ffmpeg 4.0, which versions it's libraries as .58. Fedora 27 was on ffmpeg 3.3, which is .57. Unfortunately there is only a compat library for ffmpeg 2.8, which is .56.*
Not sure there is a simple workaround here until a new makemkv-bin with makemkvconv linked against the new library is released or a compat-ffmpeg33 package is added to the repo. I may just build my own if I have to. :)
* I'm using the rpmfusion repo. Not sure if there are any alternate repos worth using these days.
Top
 Profile
PostPosted: Sat Jun 16, 2018 8:45 pm
Offline
The diff from chowbok worked for me on Debian Unstable.
Top
 Profile
PostPosted: Tue Jun 26, 2018 6:05 am
Offline
Code:
*** 517,523 ****
      if (argp) {
--- 517,523 ----
      if (argp) {
*** 718,724 ****
      info->flags = 0;
      return 0;
--- 718,724 ----
      info->flags = 0;
      return 0;
This worked for me on Fedora 28, thanks.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 20 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
