www.makemkv.com
MakeMKV support forum
It is currently Mon Jul 23, 2018 12:17 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
Author Message
PostPosted: Mon Oct 13, 2014 11:57 pm
Offline
fitzyj I have opensuse 13.1 and using makemkv 1.8.13
I've gotten further than you by following the instructions given on using the packman repositories, and switching out things.
But makemkv-oss still doesn't build, but with different errors:
make
which: no moc-qt4 in (/usr/lib64/mpi/gcc/openmpi/bin:/sbin:/usr/sbin:/usr/local/sbin:/root/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/opt/kde3/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin)
mkdir -p out
gcc -g -O2 -D_GNU_SOURCE -D_linux_ -D_REENTRANT -shared -Wl,-z,defs -oout/libdriveio.so.0.full -Ilibdriveio/inc libdriveio/src/infolist.cpp libdriveio/src/scsihlp.cpp libdriveio/src/srlist.cpp libdriveio/src/stdquery.cpp libdr
iveio/src/tipclient.cpp libdriveio/src/tipcommon.cpp libdriveio/src/tipserver.cpp libdriveio/src/drives/pioneer.cpp libdriveio/src/drives/xboxhddvd.cpp \
-fPIC -Xlinker -dy -Xlinker --version-script=libdriveio/src/libdriveio.vers \
-Xlinker -soname=libdriveio.so.0 -lc -lstdc++
objcopy --strip-all --strip-debug --strip-unneeded --discard-all out/libdriveio.so.0.full out/libdriveio.so.0
mkdir -p tmp
echo "#define BUILDINFO_ARCH_NAME \"x86_64-suse-linux\"" >> tmp/gen_buildinfo.h
echo "#define BUILDINFO_BUILD_DATE \"Mon Oct 13 18:23:47 EDT 2014\"" >> tmp/gen_buildinfo.h
mkdir -p out
gcc -g -O2 -D_GNU_SOURCE -D_linux_ -D_REENTRANT -shared -Wl,-z,defs -oout/libmakemkv.so.1.full -Ilibebml/inc -DEBML_NO_READ -DEBML_STRICT_API -DEBML_DEBUG -Ilibmatroska/inc \
-Ilibmakemkv/inc -Isstring/inc -Imakemkvgui/inc -Ilibabi/inc -Ilibffabi/inc \
libebml/src/EbmlBinary.cpp libebml/src/EbmlContexts.cpp libebml/src/EbmlCrc32.cpp libebml/src/EbmlDate.cpp libebml/src/EbmlDummy.cpp libebml/src/EbmlElement.cpp libebml/src/EbmlFloat.cpp libebml/src/EbmlHead.cpp libebml/src/Eb
mlMaster.cpp libebml/src/EbmlSInteger.cpp libebml/src/EbmlString.cpp libebml/src/EbmlSubHead.cpp libebml/src/EbmlUInteger.cpp libebml/src/EbmlUnicodeString.cpp libebml/src/EbmlVersion.cpp libebml/src/EbmlVoid.cpp libebml/src/I
OCallback.cpp libebml/src/MemIOCallback.cpp libmatroska/src/FileKax.cpp libmatroska/src/KaxAttached.cpp libmatroska/src/KaxAttachments.cpp libmatroska/src/KaxBlock.cpp libmatroska/src/KaxBlockData.cpp libmatroska/src/KaxClust
er.cpp libmatroska/src/KaxContexts.cpp libmatroska/src/KaxCues.cpp libmatroska/src/KaxCuesData.cpp libmatroska/src/KaxInfoData.cpp libmatroska/src/KaxSeekHead.cpp libmatroska/src/KaxSegment.cpp libmatroska/src/KaxTracks.cpp li
bmatroska/src/KaxVersion.cpp libmatroska/src/KaxSemantic.cpp libmakemkv/src/ebmlwrite.cpp libmakemkv/src/libmkv.cpp libmakemkv/src/version.cpp libmakemkv/src/world.cpp libmakemkv/src/stdstring.cpp sstring/src/sstring.cpp \
libabi/src/ossl_aes.c libabi/src/ossl_sha.c libabi/src/ossl_ec.c libabi/src/zlib.c libabi/src/xpat.c libabi/src/httplinux.cpp makemkvgui/src/api_linux.cpp libabi/src/sys_linux.c makemkvgui/src/spawn_posix.cpp libffabi/src/ffab
i.c libffabi/src/mlp.c libffabi/src/log.c libffabi/src/audio_convert.c libffabi/src/audio_mix.c libffabi/src/audio_mix_matrix.c \
-DHAVE_BUILDINFO_H -Itmp -I/usr/local/include \
-fPIC -Xlinker -dy -Xlinker --version-script=libmakemkv/src/libmakemkv.vers \
-Xlinker -soname=libmakemkv.so.1 -lc -lstdc++ -lcrypto -lz -lexpat -L/usr/local/lib -lavcodec -lXv -lX11 -lXext -lva -lX11 -ljack -lasound -lSDL -lpthread -lm -llzma -lbz2 -lz -pthread -lswresample -lm -lavutil -lm -lm
libffabi/src/ffabi.c: In function ‘ffm_audio_decode_init’:
libffabi/src/ffabi.c:177:5: warning: ‘avcodec_alloc_frame’ is deprecated (declared at /usr/local/include/libavcodec/avcodec.h:3545) [-Wdeprecated-declarations]
ctx->frame = avcodec_alloc_frame();
libffabi/src/ffabi.c: In function ‘ffm_audio_decode_close’:
libffabi/src/ffabi.c:190:9: warning: ‘avcodec_free_frame’ is deprecated (declared at /usr/local/include/libavcodec/avcodec.h:3570) [-Wdeprecated-declarations]
avcodec_free_frame(&ctx->frame);
libffabi/src/ffabi.c: In function ‘ffm_audio_encode_init’:
libffabi/src/ffabi.c:345:5: warning: ‘avcodec_alloc_frame’ is deprecated (declared at /usr/local/include/libavcodec/avcodec.h:3545) [-Wdeprecated-declarations]
libffabi/src/ffabi.c: In function ‘ffm_audio_encode_close’:
libffabi/src/ffabi.c:360:9: warning: ‘avcodec_free_frame’ is deprecated (declared at /usr/local/include/libavcodec/avcodec.h:3570) [-Wdeprecated-declarations]
/usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld: /usr/local/lib/libavcodec.a(allcodecs.o): relocation R_X86_64_32 against `ff_h263_vaapi_hwaccel' can not be used when making a shared object; recompile
with -fPIC
/usr/local/lib/libavcodec.a: could not read symbols: Bad value
collect2: error: ld returned 1 exit status
make: *** [out/libmakemkv.so.1.full] Error 1
Top
 Profile
PostPosted: Fri Oct 17, 2014 11:43 pm
Offline
I'm attaching my config.log
hopefully the admin will see this and someone can fix it :(
hrm I can't attach because the "board quota has been exceeded" :(
Top
 Profile
PostPosted: Mon Oct 20, 2014 9:52 pm
Offline
Can anyone help?
here's my config.log:
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by ffabi configure 0, which was
generated by GNU Autoconf 2.68. Invocation command line was
$ ./configure
## Platform. ##
hostname = mail
uname -m = x86_64
uname -r = 3.16.3-1.gd2bbe7f-desktop
uname -s = Linux
uname -v = #1 SMP PREEMPT Thu Sep 18 06:32:16 UTC 2014 (d2bbe7f)
/usr/bin/uname -p = x86_64
/bin/uname -X = unknown
/bin/arch = x86_64
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/lib64/mpi/gcc/openmpi/bin
PATH: /sbin
PATH: /usr/sbin
PATH: /usr/local/sbin
PATH: /root/bin
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/bin/X11
PATH: /usr/X11R6/bin
PATH: /usr/games
PATH: /opt/kde3/bin
PATH: /usr/lib/mit/bin
PATH: /usr/lib/mit/sbin
## Core tests. ##
configure:2401: loading site script /usr/share/site/x86_64-unknown-linux-gnu
| #!/bin/sh
| # Site script for configure. It is resourced via $CONFIG_SITE environment varaible.
| # If user did not specify libdir, guess the correct target:
| # Use lib64 for 64 bit bi-arch targets, keep the default for the rest.
| if test "$libdir" = '${exec_prefix}/lib' ; then
| ac_config_site_64bit_host=NONE
| case "$host" in
| # User did not specify host target.
| # The native platform x86_64 is a bi-arch platform.
| # Try to detect cross-compilation to inferior architecture.
| # We are trying to guess 32-bit target compilation. It's not as easy as
| # it sounds, as there is possible several intermediate combinations.
| ac_config_site_cross_to_32bit_host=NONE
| # User defined -m32 in CFLAGS or CXXFLAGS:
| # (It's sufficient for 32-bit, but alone may cause mis-behavior of some checks.)
| case "$CFLAGS" in
| *-m32*)
| ac_config_site_cross_to_32bit_host=YES
| esac
| case "$CXXFLAGS" in
| *-m32*)
| esac
| # Running with linux32:
| # (Changes detected platform, but not the toolchain target.)
| case "`/bin/uname -i`" in
| x86_64 | ppc64 | s390x )
| esac
| if test "x$ac_config_site_cross_to_32bit_host" = xNONE; then
| ac_config_site_64bit_host=YES
| fi
| *x86_64* | *ppc64* | *s390x* )
| esac
| if test "x$ac_config_site_64bit_host" = xYES; then
| libdir='${exec_prefix}/lib64'
| fi
| fi
| # If user did not specify libexecdir, set the correct target:
| # Nor FHS nor openSUSE allow prefix/libexec. Let's default to prefix/lib.
| if test "$libexecdir" = '${exec_prefix}/libexec' ; then
| libexecdir='${exec_prefix}/lib'
| fi
| # Continue with the standard behavior of configure defined in AC_SITE_LOAD:
| if test "x$prefix" != xNONE; then
| ac_site_file1=$prefix/share/config.site
| ac_site_file2=$prefix/etc/config.site
| else
| ac_site_file1=$ac_default_prefix/share/config.site
| ac_site_file2=$ac_default_prefix/etc/config.site
| fi
| for ac_site_file in "$ac_site_file1" "$ac_site_file2"
| do
| test "x$ac_site_file" = xNONE && continue
| if test /dev/null != "$ac_site_file" && test -r "$ac_site_file"; then
| { $as_echo "/usr/share/site/x86_64-unknown-linux-gnu:${as_lineno-$LINENO}: loading site script $ac_site_file" >&5
| $as_echo "/usr/share/site/x86_64-unknown-linux-gnu: loading site script $ac_site_file" >&6;}
| sed 's/^/| /' "$ac_site_file" >&5
| . "$ac_site_file" \
| || { { $as_echo "/usr/share/site/x86_64-unknown-linux-gnu:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
| $as_echo "/usr/share/site/x86_64-unknown-linux-gnu: error: in \`$ac_pwd':" >&2;}
| as_fn_error $? "failed to load site script $ac_site_file
| See \`config.log' for more details" "$LINENO" 5; }
| fi
| done
configure:2532: checking build system type
configure:2546: result: x86_64-unknown-linux-gnu
configure:2566: checking host system type
configure:2579: result: x86_64-unknown-linux-gnu
configure:2599: checking target system type
configure:2612: result: x86_64-unknown-linux-gnu
configure:2708: checking for gcc
configure:2724: found /usr/bin/gcc
configure:2735: result: gcc
configure:2964: checking for C compiler version
configure:2973: gcc --version >&5
gcc (SUSE Linux) 4.8.1 20130909 [gcc-4_8-branch revision 202388]
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:2984: $? = 0
configure:2973: gcc -v >&5
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib64/gcc/x86_64-suse-linux/4.8/lto-wrapper
Target: x86_64-suse-linux
Configured with: ../configure --prefix=/usr --infodir=/usr/share/info --mandir=/usr/share/man --libdir=/usr/lib64 --libexecdir=/usr/lib64 --enable-languages=c,c++,objc,fortran,obj-c++,java,ada --enable-checking=release --with-
gxx-include-dir=/usr/include/c++/4.8 --enable-ssp --disable-libssp --disable-plugin --with-bugurl=http://bugs.opensuse.org/ --with-pkgversion='SUSE Linux' --disable-libgcj --disable-libmudflap --with-slibdir=/lib64 --with-syst
em-zlib --enable-__cxa_atexit --enable-libstdcxx-allocator=new --disable-libstdcxx-pch --enable-version-specific-runtime-libs --enable-linker-build-id --program-suffix=-4.8 --enable-linux-futex --without-system-libunwind --wit
h-arch-32=i586 --with-tune=generic --build=x86_64-suse-linux
Thread model: posix
gcc version 4.8.1 20130909 [gcc-4_8-branch revision 202388] (SUSE Linux)
configure:2973: gcc -V >&5
gcc: error: unrecognized command line option '-V'
gcc: fatal error: no input files
compilation terminated.
configure:2984: $? = 1
configure:2973: gcc -qversion >&5
gcc: error: unrecognized command line option '-qversion'
configure:3004: checking whether the C compiler works
configure:3026: gcc conftest.c >&5
configure:3030: $? = 0
configure:3078: result: yes
configure:3081: checking for C compiler default output file name
configure:3083: result: a.out
configure:3089: checking for suffix of executables
configure:3096: gcc -o conftest conftest.c >&5
configure:3100: $? = 0
configure:3122: result:
configure:3144: checking whether we are cross compiling
configure:3152: gcc -o conftest conftest.c >&5
configure:3156: $? = 0
configure:3163: ./conftest
configure:3167: $? = 0
configure:3182: result: no
configure:3187: checking for suffix of object files
configure:3209: gcc -c conftest.c >&5
configure:3213: $? = 0
configure:3234: result: o
configure:3238: checking whether we are using the GNU C compiler
configure:3257: gcc -c conftest.c >&5
configure:3257: $? = 0
configure:3266: result: yes
configure:3275: checking whether gcc accepts -g
configure:3295: gcc -c -g conftest.c >&5
configure:3295: $? = 0
configure:3336: result: yes
configure:3353: checking for gcc option to accept ISO C89
configure:3417: gcc -c -g -O2 conftest.c >&5
configure:3417: $? = 0
configure:3430: result: none needed
configure:3508: checking for g++
configure:3524: found /usr/bin/g++
configure:3535: result: g++
configure:3562: checking for C++ compiler version
configure:3571: g++ --version >&5
g++ (SUSE Linux) 4.8.1 20130909 [gcc-4_8-branch revision 202388]
configure:3582: $? = 0
configure:3571: g++ -v >&5
COLLECT_GCC=g++
Thread model: posix
configure:3571: g++ -V >&5
g++: error: unrecognized command line option '-V'
g++: fatal error: no input files
configure:3582: $? = 1
configure:3571: g++ -qversion >&5
g++: error: unrecognized command line option '-qversion'
configure:3586: checking whether we are using the GNU C++ compiler
configure:3605: g++ -c conftest.cpp >&5
configure:3605: $? = 0
configure:3614: result: yes
configure:3623: checking whether g++ accepts -g
configure:3643: g++ -c -g conftest.cpp >&5
configure:3643: $? = 0
configure:3684: result: yes
configure:3709: checking for -objcopy
configure:3739: result: no
configure:3749: checking for objcopy
configure:3765: found /usr/bin/objcopy
configure:3777: result: objcopy
configure:3794: checking for -ld
configure:3824: result: no
configure:3834: checking for ld
configure:3850: found /usr/bin/ld
configure:3862: result: ld
configure:3893: checking for a BSD-compatible install
configure:3961: result: /usr/bin/install -c
configure:3984: checking how to run the C preprocessor
configure:4015: gcc -E conftest.c
configure:4015: $? = 0
configure:4029: gcc -E conftest.c
conftest.c:9:28: fatal error: ac_nonexistent.h: No such file or directory
#include <ac_nonexistent.h>
configure:4029: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "ffabi"
| #define PACKAGE_TARNAME "ffabi"
| #define PACKAGE_VERSION "0"
| #define PACKAGE_STRING "ffabi 0"
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL ""
| /* end confdefs.h. */
configure:4054: result: gcc -E
configure:4074: gcc -E conftest.c
configure:4074: $? = 0
configure:4088: gcc -E conftest.c
configure:4088: $? = 1
| /* confdefs.h */
configure:4117: checking for grep that handles long lines and -e
configure:4175: result: /usr/bin/grep
configure:4180: checking for egrep
configure:4242: result: /usr/bin/grep -E
configure:4247: checking for ANSI C header files
configure:4267: gcc -c -g -O2 conftest.c >&5
configure:4267: $? = 0
configure:4340: gcc -o conftest -g -O2 conftest.c >&5
configure:4340: $? = 0
configure:4340: ./conftest
configure:4351: result: yes
configure:4364: checking for sys/types.h
configure:4364: gcc -c -g -O2 conftest.c >&5
configure:4364: $? = 0
configure:4364: result: yes
configure:4364: checking for sys/stat.h
configure:4364: checking for stdlib.h
configure:4364: checking for string.h
configure:4364: checking for memory.h
configure:4364: checking for strings.h
configure:4364: checking for inttypes.h
configure:4364: checking for stdint.h
configure:4364: checking for unistd.h
configure:4378: checking zlib.h usability
configure:4378: gcc -c -g -O2 conftest.c >&5
configure:4378: $? = 0
configure:4378: result: yes
configure:4378: checking zlib.h presence
configure:4378: gcc -E conftest.c
configure:4378: checking for zlib.h
configure:4395: checking for compress2 in -lz
configure:4420: gcc -o conftest -g -O2 conftest.c -lz >&5
configure:4420: $? = 0
configure:4429: result: yes
configure:4451: checking openssl/opensslconf.h usability
configure:4451: gcc -c -g -O2 conftest.c >&5
configure:4451: $? = 0
configure:4451: result: yes
configure:4451: checking openssl/opensslconf.h presence
configure:4451: gcc -E conftest.c
configure:4451: checking for openssl/opensslconf.h
configure:4468: checking for AES_encrypt in -lcrypto
configure:4493: gcc -o conftest -g -O2 conftest.c -lcrypto -lz >&5
configure:4493: $? = 0
configure:4502: result: yes
configure:4524: checking expat.h usability
configure:4524: gcc -c -g -O2 conftest.c >&5
configure:4524: $? = 0
configure:4524: result: yes
configure:4524: checking expat.h presence
configure:4524: gcc -E conftest.c
configure:4524: checking for expat.h
configure:4541: checking for XML_ParserCreate in -lexpat
configure:4566: gcc -o conftest -g -O2 conftest.c -lexpat -lcrypto -lz >&5
configure:4566: $? = 0
configure:4575: result: yes
configure:4649: checking for pkg-config
configure:4667: found /usr/bin/pkg-config
configure:4679: result: /usr/bin/pkg-config
configure:4704: checking pkg-config is at least version 0.9.0
configure:4707: result: yes
configure:4717: checking for ffmpeg
configure:4724: $PKG_CONFIG --exists --print-errors "libavcodec libavutil"
configure:4727: $? = 0
configure:4741: $PKG_CONFIG --exists --print-errors "libavcodec libavutil"
configure:4744: $? = 0
configure:4782: result: yes
configure:4791: checking whether LIBAVCODEC_VERSION_MAJOR is declared
configure:4791: gcc -c -g -O2 -I/usr/local/include conftest.c >&5
configure:4791: $? = 0
configure:4791: result: yes
configure:4805: checking LIBAVCODEC_VERSION_MAJOR
configure:4807: gcc -o conftest -g -O2 -I/usr/local/include conftest.c -lexpat -lcrypto -lz -L/usr/local/lib -lavcodec -lXv -lX11 -lXext -lva -lX11 -ljack -lasound -lSDL -lpthread -lm -llzma -lbz2 -lz -pthread -lswresample
-lm -lavutil -lm >&5
configure:4807: $? = 0
configure:4807: ./conftest
configure:4822: result: 56
configure:4826: checking for AVFrame.nb_samples
configure:4826: gcc -c -g -O2 -I/usr/local/include conftest.c >&5
configure:4826: $? = 0
configure:4826: result: yes
configure:4838: checking whether AV_SAMPLE_FMT_U8P is declared
configure:4838: gcc -c -g -O2 -I/usr/local/include conftest.c >&5
configure:4838: $? = 0
configure:4838: result: yes
configure:4850: checking for avcodec_encode_audio2
configure:4850: gcc -o conftest -g -O2 -I/usr/local/include conftest.c -lexpat -lcrypto -lz -L/usr/local/lib -lavcodec -lXv -lX11 -lXext -lva -lX11 -ljack -lasound -lSDL -lpthread -lm -llzma -lbz2 -lz -pthread -lswresample
configure:4850: $? = 0
configure:4850: result: yes
configure:4865: checking for AVCodecContext.refcounted_frames
configure:4865: gcc -c -g -O2 -I/usr/local/include conftest.c >&5
configure:4865: $? = 0
configure:4865: result: yes
configure:4876: checking whether avcodec_free_frame is declared
configure:4876: gcc -c -g -O2 -I/usr/local/include conftest.c >&5
conftest.c: In function 'main':
conftest.c:35:3: warning: 'avcodec_free_frame' is deprecated (declared at /usr/local/include/libavcodec/avcodec.h:3570) [-Wdeprecated-declarations]
(void) avcodec_free_frame;
configure:4876: $? = 0
configure:4876: result: yes
configure:4887: checking for av_log_format_line
configure:4887: gcc -o conftest -g -O2 -I/usr/local/include conftest.c -lexpat -lcrypto -lz -L/usr/local/lib -lavcodec -lXv -lX11 -lXext -lva -lX11 -ljack -lasound -lSDL -lpthread -lm -llzma -lbz2 -lz -pthread -lswresample
configure:4887: $? = 0
configure:4887: result: yes
configure:4897: checking for enum AVCodecID
configure:4897: gcc -c -g -O2 -I/usr/local/include conftest.c >&5
configure:4897: $? = 0
conftest.c:33:29: error: expected expression before ')' token
if (sizeof ((enum AVCodecID)))
configure:4897: $? = 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_ZLIB_H 1
| #define HAVE_LIBZ 1
| #define HAVE_OPENSSL_OPENSSLCONF_H 1
| #define HAVE_LIBCRYPTO 1
| #define HAVE_EXPAT_H 1
| #define HAVE_LIBEXPAT 1
| #define FFABI_HAVE_REFCOUNTED_FRAMES 1
| #define FFABI_HAVE_AVCODEC_FREE_FRAME 1
| #define FFABI_HAVE_AV_LOG_FORMAT_LINE 1
| #include <libavcodec/avcodec.h>
| int
| main ()
| return 0;
| return 0;
configure:4897: result: yes
configure:4921: checking whether AV_CODEC_ID_NONE is declared
configure:4921: gcc -c -g -O2 -I/usr/local/include conftest.c >&5
configure:4921: $? = 0
configure:4921: result: yes
configure:4945: checking whether av_frame_get_channels is declared
configure:4945: gcc -c -g -O2 -I/usr/local/include conftest.c >&5
configure:4945: $? = 0
configure:4945: result: yes
configure:4956: checking whether av_frame_get_sample_rate is declared
configure:4956: gcc -c -g -O2 -I/usr/local/include conftest.c >&5
configure:4956: $? = 0
configure:4956: result: yes
configure:4967: checking whether av_frame_set_channel_layout is declared
configure:4967: gcc -c -g -O2 -I/usr/local/include conftest.c >&5
configure:4967: $? = 0
configure:4967: result: yes
configure:4978: checking for AVCodecParserContext.duration
configure:4978: gcc -c -g -O2 -I/usr/local/include conftest.c >&5
configure:4978: $? = 0
configure:4978: result: yes
configure:4989: checking whether AV_CH_TOP_BACK_CENTER is declared
configure:4989: gcc -c -g -O2 -I/usr/local/include conftest.c >&5
configure:4989: $? = 0
configure:4989: result: yes
configure:5116: creating ./config.status
## Running config.status. ##
This file was extended by ffabi config.status 0, which was
CONFIG_FILES =
CONFIG_HEADERS =
CONFIG_LINKS =
CONFIG_COMMANDS =
$ ./config.status
on mail
config.status:855: creating Makefile
config.status:855: creating libffabi/src/ffabicfg.h
## Cache variables. ##
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_c_compiler_gnu=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_DESTDIR_set=
ac_cv_env_DESTDIR_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_PKG_CONFIG_LIBDIR_set=
ac_cv_env_PKG_CONFIG_LIBDIR_value=
ac_cv_env_PKG_CONFIG_PATH_set=
ac_cv_env_PKG_CONFIG_PATH_value=
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_ffmpeg_CFLAGS_set=
ac_cv_env_ffmpeg_CFLAGS_value=
ac_cv_env_ffmpeg_LIBS_set=
ac_cv_env_ffmpeg_LIBS_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_func_av_log_format_line=yes
ac_cv_func_avcodec_encode_audio2=yes
ac_cv_have_decl_AV_CH_TOP_BACK_CENTER=yes
ac_cv_have_decl_AV_CODEC_ID_NONE=yes
ac_cv_have_decl_AV_SAMPLE_FMT_U8P=yes
ac_cv_have_decl_LIBAVCODEC_VERSION_MAJOR=yes
ac_cv_have_decl_av_frame_get_channels=yes
ac_cv_have_decl_av_frame_get_sample_rate=yes
ac_cv_have_decl_av_frame_set_channel_layout=yes
ac_cv_have_decl_avcodec_free_frame=yes
ac_cv_header_expat_h=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_openssl_opensslconf_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_header_zlib_h=yes
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_lib_crypto_AES_encrypt=yes
ac_cv_lib_expat_XML_ParserCreate=yes
ac_cv_lib_z_compress2=yes
ac_cv_member_AVCodecContext_refcounted_frames=yes
ac_cv_member_AVCodecParserContext_duration=yes
ac_cv_member_AVFrame_nb_samples=yes
ac_cv_objext=o
ac_cv_path_EGREP='/usr/bin/grep -E'
ac_cv_path_GREP=/usr/bin/grep
ac_cv_path_ac_pt_PKG_CONFIG=/usr/bin/pkg-config
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_CPP='gcc -E'
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_ac_ct_LD=ld
ac_cv_prog_ac_ct_OBJCOPY=objcopy
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_target=x86_64-unknown-linux-gnu
ac_cv_type_enum_AVCodecID=yes
pkg_cv_ffmpeg_CFLAGS='-I/usr/local/include '
pkg_cv_ffmpeg_LIBS='-L/usr/local/lib -lavcodec -lXv -lX11 -lXext -lva -lX11 -ljack -lasound -lSDL -lpthread -lm -llzma -lbz2 -lz -pthread -lswresample -lm -lavutil -lm '
## Output variables. ##
CC='gcc'
CFLAGS='-g -O2 -I/usr/local/include '
CFLAGS_OPT='-g -O2'
CPP='gcc -E'
CPPFLAGS=''
CXX='g++'
CXXFLAGS='-g -O2'
DEFS='-DHAVE_CONFIG_H'
DESTDIR=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
ENABLE_GUI='yes'
EXEEXT=''
GREP='/usr/bin/grep'
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
LD='ld'
LDFLAGS=''
LIBOBJS=''
LIBS='-lexpat -lcrypto -lz -L/usr/local/lib -lavcodec -lXv -lX11 -lXext -lva -lX11 -ljack -lasound -lSDL -lpthread -lm -llzma -lbz2 -lz -pthread -lswresample -lm -lavutil -lm '
LTLIBOBJS=''
OBJCOPY='objcopy'
OBJEXT='o'
PACKAGE_BUGREPORT=''
PACKAGE_NAME='ffabi'
PACKAGE_STRING='ffabi 0'
PACKAGE_TARNAME='ffabi'
PACKAGE_URL=''
PACKAGE_VERSION='0'
PATH_SEPARATOR=':'
PKG_CONFIG='/usr/bin/pkg-config'
PKG_CONFIG_LIBDIR=''
PKG_CONFIG_PATH=''
SHELL='/bin/sh'
ac_ct_CC='gcc'
ac_ct_CXX='g++'
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='${prefix}'
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='/usr'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target='x86_64-unknown-linux-gnu'
target_alias=''
target_cpu='x86_64'
target_os='linux-gnu'
target_vendor='unknown'
## confdefs.h. ##
/* confdefs.h */
#define HAVE_LIBZ 1
#define FFABI_HAVE_AVCODECID 1
#define FFABI_HAVE_AV_CODEC_ID_NAMES 1
#define FFABI_HAVE_AV_FRAME_CHANNELS 1
#define FFABI_HAVE_AV_FRAME_SAMPLE_RATE 1
#define FFABI_HAVE_AV_FRAME_CHANNEL_LAYOUT 1
#define FFABI_HAVE_PARSER_DURATION 1
#define FFABI_HAVE_AVUTIL_CHANNEL_LAYOUT_H 1
configure: exit 0
Top
 Profile
PostPosted: Wed Jul 27, 2016 6:57 pm
Offline
Here's what you have to do on openSUSE tumbleweed, MakeMKV 1.10.0 (and probably higher)
1.) Download makemkv-oss-*.tar.gz and makemkv-bin-*.tar.gz from the thread "MakeMKV * is available for Linux" (* is the current version of MakeMKV)
2.) Add the Packman Repository
3.) Open a terminal window / konsole and run
Code:
sudo zypper in gcc zlib-devel openssl-devel libexpat-devel libavutil-devel ffmpeg-devel libqt5-qtbase-devel
NOTE: you might need to downgrade libpostproc53 in order to install ffmpeg-devel
4.) In konsole/terminal, navigate to the folder you've downloaded the two makemkv-files (oss, bin) into (e.g. 'cd Downloads') and run
Code:
tar -xvf makemkv-oss-1.10.0.tar.gz
tar -xvf makemkv-bin-1.10.0.tar.gz
(Adapt version numbers if applicable)
5. In the same konsole / terminal window:
Code:
cd makemkv-oss-1.10.0
./configure
make
sudo make install
(Again, adapt version number if needed)
6. Still in the same konsole / terminal window:
Code:
cd ../makemkv-bin-1.10.0
make
sudo make install
(Once more: adapt version numbers if needed).
After that, you can start MakeMKV (e.g. by using KRunner, from the command line, etc.)
Top
 Profile
PostPosted: Wed Jun 28, 2017 8:07 am
Offline
I followed all instruction and faces no issue in installing MakeMKV for openSuSE. Thanks....
Top
 Profile
PostPosted: Sat May 05, 2018 9:07 pm
Offline
lsb_release -a
LSB Version: core-5.0-amd64:core-5.0-noarch:desktop-5.0-amd64:desktop-5.0-noarch:imaging-5.0-amd64:imaging-5.0-noarch:languages-5.0-amd64:languages-5.0-noarch
Distributor ID: openSUSE project
Description: openSUSE Leap 42.3
Release: 42.3
uname -a
Linux linux-dtopws 4.4.126-48-default #1 SMP Sat Apr 7 05:22:50 UTC 2018 (f24992c) x86_64 x86_64 x86_64 GNU/Linux
Upgrade from prev. ver. to 1.12.2
May 5th, 2018,
Code:
sudo zypper refresh
Code:
sudo zypper dist-upgrade
Code:
tar -xvf makemkv-oss*.tar.gz
cd makemkv-oss*/
./configure
make
sudo make install
Code:
tar -xvf makemkv-bin*.tar.gz
cd makemkv-bin*/
make
 - (Type 'q', then 'yes' to accept the license.)
sudo make install
Worked great~Thanks!!!
Top
 Profile
PostPosted: Fri Jun 01, 2018 2:23 am
Offline
openSuse 15.0
Just had to add:
Code:
sudo zypper install libexpat-devel
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 12 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
