Converting DTS-HD MA or ripping the same as LPCM
Re: Converting DTS-HD MA or ripping the same as LPCM
mudstuff wrote:
Thu Dec 07, 2023 3:44 pm
Hi, I'd love some help on this if possible. I copied the code you kindly provided, saved as xml and named it LPCM.xml in the make mkv data folder. No new profile appears though, could you help?
My file is named lcpmtest.mmcp.xml.
mudstuff
Post by mudstuff »
Thank you, I'm not sure if it was the renaming or the fact I initially did it with notepad and used Notepad++ second time around but it's now showing in the profile list.
