Green Room multiple playlists
Re: Green Room multiple playlists
Anyone know what file to use for the Canadian version?
Does anyone know the correct playlist for the following UPC: 031398245605
It's the standard U.S. retail version. I don't have playlist 764 on mine.
Anyone know the correct playlist for the netflix version?
It appears that 00764.mpls is also correct for Netflix. You won't see it in the list however. It's located at the top as Green Room - 16 chapter(s), 18.1 GB (FPL_MainFeature). Click on it and you'll get the following title info.carboranadum wrote:Anyone know the correct playlist for the netflix version?
Title information
Comment: FPL_MainFeature
Source file name: 00764.mpls
Duration: 1:35:01
Chapters count: 16
Segment count: 20
Segment map: 506,512,520,519,507,509,513,508,517,516,511,514,515,502,505,518,501,504,503,510
File name: Green_Room_t02.mkv
I'm going to test it now, but I think we have a winner.
Confirmed. Watched the 00764 rip and the BluRay in two windows and they matched.brellyn wrote:It appears that 00764.mpls is also correct for Netflix.
If anyone is looking for the correct MPLS for the Canadian version, I found it! The Canadian MPLS is 00918. It took a LOT of legwork to sift through it all, as there had to be well over 200 playlists (I didn't count). As for the exact version/provider, I got mine used from a rental shop. I hope this helps!Uatu. wrote:Anyone know what file to use for the Canadian version?
Title information
Name: Green Room (English)
Source file name: 00918.mpls(1)
Duration: 1:35:01
Chapters count: 15
Segment count: 20
Segment map: 519,513,509,517,504,501,508,515,516,511,2857,507,520,512,510,503,514,506,518,502
File name: Green_Room_t275.mkv
You ever figure this one out? I have the same UPC (bought at store) and I DO have 764?ingen1ous wrote:Does anyone know the correct playlist for the following UPC: 031398245605
mine looks like this
- green rm.JPG (19.97 KiB) Viewed 9080 times
