UH12NS40 Firmware 1.0
petrob
Post by petrob » Wed Nov 28, 2018 7:54 pm
Bought an LG UH12NS40 drive which came with a "fixed" 1.01 firmware. LG website only has this firmware available (of course!). Any member here has this drive with the original UHD-friendly 1.00 firmware? Can I crossflash ASUS BC-12D2HT firmware on this? Specs for both look pretty similar. Any help is appreciated. Thanks!
st4evr
Re: UH12NS40 Firmware 1.0
Post by st4evr » Wed Nov 28, 2018 8:45 pm
You can check these threads (and links within) to see if 1.00 Friendly for that drive is posted as a starting point with the downgrade tools/instructions provided:
https://www.makemkv.com/forum/viewtopic ... 16&t=16832
https://www.makemkv.com/forum/viewtopic ... 16&t=17058
https://www.makemkv.com/forum/viewtopic ... 16&t=18251
Or by members who have posted within that thread.
petrob
Post by petrob » Wed Nov 28, 2018 9:17 pm
Nothing in those links. Only a 3.00 dump of the Asus BC-12D2HT firmware. One member (Terramax) suggests to flash the BC-12D2HT with the BW-16D1HT firmware. Can flashing a read-only drive (BC) with a writer (BW) firmware cause problems? I wouldn't expect my drive to be able to burn discs all of a sudden :D but I don't want to brick it either!
jonghotti
Post by jonghotti » Sun Dec 02, 2018 8:38 am
I suggest the same thing, it will work. I have 7 of those drives sitting here all flashed to ASUS 3.01 and hitting the high speeds during rips just like an ASUS.
I sell UHD Friendly drives in the USA and anywhere else in the world they're used!
petrob
Post by petrob » Mon Dec 03, 2018 8:16 pm
Cool! I'll try it! Thanks for the feedback!
troybos
Post by troybos » Sun Dec 16, 2018 4:16 am
petrob...did you ever successfully flash your UH12NS40 to a firmware that could read UHD? What firmware did you use and could you share the process? Thanks
jonghotti
Post by jonghotti » Sun Dec 16, 2018 5:42 am
Use the same process used for flashing any other drive and use the Asus Bw16d1ht 3.01 firmware.
Or better yet buy a couple from me they’re cheap and I’ve got 8 pre flashed and tested units in stock
troybos
Post by troybos » Sun Dec 16, 2018 6:42 pm
How do I contact you about your prices?
jonghotti
Post by jonghotti » Sun Dec 16, 2018 7:25 pm
