New PC build came with BH16NS40 - safe to patch?
I just got delivery of my new 3950X PC and i discovered that the builder put in a decent drive.
I am not 100% sure if i can flash this however as it is one of the encrypted ones.
Most importantly...Can it even read UHD discs?
Thanks all - details below
OS device name: E:
Product: BD-RE BH16NS40
Revision: 1.05
Serial number: xxxxxxxxx
Firmware date: 2120-05-06 13:31
Harware support: Yes
Firmware support: No
Firmware version: 1.05
OS device name: E:
Revision: 1.05
Re: New PC build came with BH16NS40 - safe to patch?
Yep, it can be flashed and yes it will be able to read UHD's.mm8718 wrote: ↑Wed Feb 17, 2021 11:45 pmI just got delivery of my new 3950X PC and i discovered that the builder put in a decent drive.
OS device name: E:
Revision: 1.05
For UHD enabled drives (AU/NZ/SG) & DIY Single Drive Flasher (WW): https://www.uhdenableddrives.com
Thanks @MartyMcNutsMartyMcNuts wrote: ↑Thu Feb 18, 2021 2:17 am
Can I just use your guide (SDF tool) and select the 'enc' flag when I flash?
Yep, sure can!mm8718 wrote: ↑Thu Feb 18, 2021 8:49 pmThanks @MartyMcNutsMartyMcNuts wrote: ↑Thu Feb 18, 2021 2:17 am
Thank you sir!MartyMcNuts wrote: ↑Thu Feb 18, 2021 10:27 pmYep, sure can!mm8718 wrote: ↑Thu Feb 18, 2021 8:49 pmThanks @MartyMcNutsMartyMcNuts wrote: ↑Thu Feb 18, 2021 2:17 am
Hi @MartyMcNuts
Sorry for revisiting this post but i finally flashed the firmware for the drive today using your tool, checked the encrypted option - flasging worked and i can see MakeMKV recognising it as flashed, however i tried 3 4K disks today and the first one came with lots of reading errors by MakeMKV and the other 2 were not recognised at all.
All i did was flashed, restarted my machine.
Am i doing anythign wrong? I did do a dump of the original firmware in case i need to recover the drive but i hope not. The discs are brand new, 4K version of Lord of the rings Fellowship part 1 &2 and Once Upon a Time in Hollywood.
Suggestions welcome!
This is how MKV is reading the drive now...note this is with a disc loaded!:
OS device name: E:
Revision: 1.05
Serial number: KL7KAT81109
Highest AACS version: 76
Is this likely to be the sleeping bug? it spins for a while and then it kind of gives up.
I checked with some older dvd's and they can be read ok.
OS device name: E:
Revision: 1.05
You should clead all UHDs before inserting. Even brand new and looking pristine. Wash with warm water and liquid soap. Dry with paper towel. Wipe then with a microfiber cloth e.g. the ones used for cleaning glasses. Try again.
I think this clean the disk thing is an overly used comment and not accurate in 90% of the cases.
I'm in a similar boat here, but I'll create a new thread.
This is not a clean disc issue. 3 discs in a row is a bit of a coincidence. I kept opening and closing the tray and eventually it accepted the Once Upon a Hollywood film and it's almost finished now.
No luck with the LoTR discs yet.
Besides my older and significantly more user and abused DVDs are working just fine!!!
Yes, cleaning the discs is usually the first step to resolve these issues.mm8718 wrote: ↑Thu Feb 25, 2021 6:00 pmThis is not a clean disc issue. 3 discs in a row is a bit of a coincidence. I kept opening and closing the tray and eventually it accepted the Once Upon a Hollywood film and it's almost finished now.
Also, I suggest using a better firmware such as WH16NS60 1.02 from the MK firmware pack (in the old folder). Essentially anything but staying on 1.05. The newer firmwares majorly suck. On your current firmware, the sleep bug will kick in if a UHD is left unread for more than 2 mins.
Also, I recommend downgrading to MakeMKV version 1.15.2. Plenty of folk have had issues using 1.15.4.
FYI: The LOTR and GoT UHD boxsets have been quite troublesome for most people when ripping.
Hi MartyMartyMcNuts wrote: ↑Thu Feb 25, 2021 11:13 pm
Not sure how but after it copied the first disk, I tried the LoTR ones and for whatever reason it did read them and copied them ok. No special intervention other than shutting down and letting it be for a few minutes.
Copied ok, two parts merged, produced a nice 172GB file and Handbrake is busy reducing it now. All behaves as it should.
Will see what happens on the next rip as if it works now I would rather not mess with the firmware again.
The 1.02....thought that was for a different drive all together? Will give that a shot if I come across any issues.
Yep, if it's now working, leave as is. If you decide to change, as I said before, WH16NS60 1.02 from the MK firmware pack is a good firmware. It's faster and no sleep bug.mm8718 wrote: ↑Thu Feb 25, 2021 11:54 pmHi MartyMartyMcNuts wrote: ↑Thu Feb 25, 2021 11:13 pm
Thanks Marty
I am assuming I can just override existing firmware...i.e. just flash on top of the 1.05 I have now?
Yep.
