Direct Access
crazybug
Direct Access
Post by crazybug »
I am a little unsure if this is a MakeMKV or a KODI problem.
When I try to watch a bluray in Kodi, MakeMKV gives an error that I should read the logs and is not able to play bd.
This is the debug log:
Debug log started at Thu Nov  3 12:57:09 2016 , written by MakeMKV v1.10.2 linux(x64-release)
001005:0000 MakeMKV v1.10.2 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/kodi/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at G-g>a"LBa.>$*joL!1Kk:29398760
003006:0000 Opening files on harddrive at /media/bluray
DEBUG: Code 2147483648 at 1!>*=,~!{9fSK;|9:121265315
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at vAMlHF0]{?@\'Y%K:213132146
001003:0020 DEBUG: Code 0 at vAMlHF0]{?@\'Y%K:29397817
Application exited at Thu Nov  3 12:57:13 2016
It looks like it tries to play from /media/bluray. Is there an option to force MakeMKV to read from /dev/[sr0|dvd|bluray|cdrom] instead?
cheers
Re: Direct Access
Are you running MakeMKV from the command line or as the graphic user interface (GUI) ?
crazybug
Re: Direct Access
Post by crazybug »
Kodi is using libmm.so, so neither nor. I am loading MakeMKV in kodi.
I am trying to locate the problem. Eigther MakeMKV libmm does not notice that /media/bluray is a mountpoint and not a device, or kodi is doing something wrong by giving the mountpoint to MakeMKV libmm.so.
