Help installing MakeMKV
Xamous
Post by Xamous » Sat Jun 29, 2019 5:47 am
I'm currently trying to install MakeMKV and am having problems. I followed the steps and commands there but have yet to get a .tar.gz file to successfully install. It looked like all went well during the terminal installation but then afterwards when trying to navigate to the folder I cannot find the program anywhere and have even done searches. If anyone could tell me where that would be awesome. Thanks!
wmcclain
Re: Help installing MakeMKV
Post by wmcclain » Sun Jun 30, 2019 12:37 pm
What linux distribution are you using?
It would be helpful if you could post the exact commands you are using and the complete output from each.
