Deselect closed captions when using makemkvcon
keithhelms
Post by keithhelms »
I've been merrily extracting dozens of DVDs using makemkvcon version 1.14.5 and then, boom, I ran into a disc that apparently has closed captioning subtitles. Makemkvcon gave me an error that it couldn't find ccextractor and aborted.
I want to extract the regular subtitles, but not the closed captioned ones. How do I modify the defaultSelection string to ignore those?
I'm using Xubuntu 18.04 and I checked and ccextractor is not in the Ubuntu repository.
keithhelms
Re: Deselect closed captions when using makemkvcon
The track selection rules supposedly support the following
N - matches if Nth (or bigger) track of the same type and language
But I couldn't find ANY examples of how to use that option. Since the closed captions were the 3rd subtitle, I figured if I could tell makemkvcon to only pull the first 2 subtitles that would get around the problem.
I tried the following combinations and all of them failed with invalid token
+sel:(subtitle*eng(2))
+sel:((subtitle*eng)*2)
+sel:(subtitle*eng*2)
+sel:(subtitle(eng|2))
+sel:(subtitle*2)
+sel:(subtitle*(2))
keithhelms
Okay, this is turning into a PITA. I found the deb file for ccextractor in the Ubuntu 18.10 repository, downloaded it and installed it on 18.04. The install didn't give any errors and when I run ccextractor from the command line with no parameters it gives a nice long list of options. It installed into /usr/bin, so I went into the MakeMKV preferences and set the ccextractor location to /usr/bin.
Now when I try to run makemkvcon against the dvd that has closed captions, I get the following error
MSG:4041,0,2,"Failed to execute external program 'ccextractor' from location '/usr/bin'","Failed to execute external program '%1' from location '%2'","ccextractor","/usr/bin"
In my opinion, this whole feature violates the standalone nature of MakeMKV, where the install procedure includes all the commands you need to get the product to work.
keithhelms
To end this conversation I'm having with myself, I got it working. Apparently the MakeMKV text box that prompts you for ccextractor location actually wants the ccextractor executable. I'll nitpick a little here because to me "location" means where something is, as in what directory. Even the error message "Failed to execute external program 'ccextractor' from location '/usr/bin'" LOOKS like it is trying to execute /usr/bin/ccextractor.
So now MakeMKV can waste cycles OCRing closed captions which I am not interested in in the first place, but there is apparently no way to make it NOT do that.
wmcclain
Post by wmcclain »
Using /usr/bin/true as the executable dummies out the operation. Not many cycles wasted.
