Copy complete. 0 titles saved, 1 failed.
EekTheCat
Post by EekTheCat »
Hi;
I've been using MakeMKV to transfer my DVDs to MKV for playback from my media centre. Generally, everything works smoothly, looks like a very promising product indeed, but I have a number of troublesome DVDs. When I try to rip the main title, I get the not very specific error:
One examle is the first of the X-Men movies - here's the debug log:
Debug log started at Thu Aug 19 14:58:45 2010 , written by MakeMKV v1.5.8 win(x64-release)
001005:0000 MakeMKV v1.5.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\someone/MakeMKV_log.txt
003028:0000 Title #0 was added (15 cell(s), 1:39:53)
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory E:/Temp/Movies/XMEN1
001003:0020 DEBUG: Code 182 at 6r|NIE,|Ypx5L/;D+3XzPc:121261865
001003:0020 DEBUG: Code 832 at Xx?t\%'u.k;,A)R.CQ8*l:213132974
001003:0020 DEBUG: Code 0 at jPp$]szpU9H*E,a%Vo<:121262716
001003:0020 DEBUG: Code 0 at Xx?t\%'u.k;,A)R.CQ8*l:29397449
001003:0020 DEBUG: Code 0 at 2rn9)J;%$tM]gNj!?H\:29395379
FS ID=<FAILED> C=0
005003:0000 Failed to save title 0 to file E:/Temp/Movies/XMEN1/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Thu Aug 19 15:03:01 2010
It shouldn't be related to scratches etc. as some of the DVDs are completely new.
To try and work around this, I have tried to create a DVD ISO containing only the title in question using AnyDVD. Then I mounted that ISO as a virtual drive and tried ripping that again using MakeMKV. I got the exact same error.
I can supply an ISO reproducing the error for analysis if that is of any help.
Re: Copy complete. 0 titles saved, 1 failed.
Post by mike admin »
It looks like data on the disc is invalid. Can you try to open the disc with different dvd-drive? How soon the error happens after you press "make mkv" button?
Also, you can open iso file directly by MakeMKV without mounting it in virtual drive, it will be faster.
funkysven_4
Post by funkysven_4 »
I just had the same issue with MakeMKV aswell. Worked fine for one disc and then doesn't work now. Might try and uninstall and reinstall and see if this works. Is this a common problem?
It's unlikely that you have the same issue. Please submit debug log from your problem.
masterjay
Post by masterjay »
I have a similar problem.
Tried to make mkv with IronMan 2
Everything seems fine during the process but when it's almost finished, it failes to save the file and stops.
I have tried to save it on different disks but still not working.
The disk plays well and there is no protection on it. Have rip both to img and folder structure. Tried to use img and folder.
(is there a log somewhere in the app that can tell me more?)
setarip_old
Post by setarip_old »
@masterjay
Hi!
Tried to make mkv with IronMan 2... The disk plays well and there is no protection on it.
All original, commercial DVDs of "IronMan2" certainly do have copy protection...
SubFixer
Post by SubFixer »
I also have the same problem. I even reripped and made a new disc, but it gives me the same error. (I have to say I was trying to manipulate these files in another program and it always gave me a "missing NAV packets" error, maybe that's related).
  • Debug log started at Mon Sep 06 23:48:05 2010 , written by MakeMKV v1.5.8 win(x86-release)
    Using 259200KB for read cache.
    001005:0000 MakeMKV v1.5.8 win(x86-release) started
    001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Administrator/MakeMKV_log.txt
    003002:0000 Calculated BUP offset does not match one in IFO header.
    003028:0000 Title #0 was added (10 cell(s), 1:31:53)
    001003:0020 DEBUG: Code 2025 at Oy!ub2q;J4=`E+L}|J}?g:213132974 {Repeats 50+ times}
    005014:0000 Saving 1 titles into directory F:/Video/CHINESE_GHOST_STORY
    001003:0020 DEBUG: Code 0 at S^0$}(^zSSTWtHDSK*$:29397334
    001003:0020 DEBUG: Code 0 at S^0$}(^zSSTWtHDSK*$:121261888
    FS ID=V_MPEG2 C=1
    C_00000=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
    001003:0020 DEBUG: Code 0 at S^0$}(^zSSTWtHDSK*$:29393838
    001003:0020 DEBUG: Code 0 at Oy!ub2q;J4=`E+L}|J}?g:121265775
    001003:0020 DEBUG: Code 0 at l_zlxE7Q^,2`8 .Rw,0:213130490
    001003:0020 DEBUG: Code 0 at l_zlxE7Q^,2`8 .Rw,0:121263567
    005003:0000 Failed to save title 0 to file F:/Video/CHINESE_GHOST_STORY/title00.mkv
VOB file is corrupted beyond repair. You have a bad source.
Stryker412
Post by Stryker412 »
I'm having the same issue, here is my log file.
Debug log started at Sat Sep 18 14:14:37 2010 , written by MakeMKV v1.6.0 win(x64-release)
001005:0000 MakeMKV v1.6.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\admin/MakeMKV_log.txt
DISCID=0C562F84E06B226D69B53009D496D425D4BAFF92
005014:0000 Saving 1 titles into directory F:/Video/XMEN3
001003:0020 DEBUG: Code 7 at TF(=\P&/_wGL>m6PIvFM:121264050
001003:0020 DEBUG: Code 0 at A/g'goY"dcOFcea@e@@Go:29397449
001003:0020 DEBUG: Code 0 at 8a;4xqx++vbtp=E-85I:121263751
FS ID=V_MPEG4/ISO/AVC C=1
TI=ZeNpjZIAAB1E7B0YGTCDQt0IZRKczkA4a2BkYLFgQ9IFYBoaXzAwMTFCjQfYBAF91Bkg=
C_00000=ZeNprePXu2aNkBob/UMCABv6jAWagGBMQ60FpGFiLYDJxGgBJ1ox3G4vEgQxdNlZZ8Xc9CT98BW/2XONgUOCZlebuaGly6P
+fhoa/DQ3/GTk5WcRfbWRgYGZwaABqEE2cJVhwHcRFILYvQAmJRAb7kwvFOSLrUSSZTkHk5B9luB4Si8cqx/0FaGbrdDQ5AA3AQX8=
005003:0000 Failed to save title 0 to file F:/Video/XMEN3/title00.mkv
Stryker412 wrote:I'm having the same issue, here is my log file.
Your issue is different. Are you opening a commercial blu-ray disc or a home-made rip?
jaylah11
Post by jaylah11 »
I am trying this for the first time and i thought I was just doing it wrong so I put a different DVD in and it seemed to work. This DVD was a box set but it was made on a DVD-R I am not sure if that makes a difference but I just read that on the DVD itself. Here is what I get after the error box.
Title #0 was added (1 cell(s), 2:09:09)
Saving 1 titles into directory C:/Video/IS61_DVD_TEMPLATE
Failed to save title 0 to file C:/Video/IS61_DVD_TEMPLATE/title00.mkv
smckenzie
Post by smckenzie »
Been digitizing our dvd collection and have encountered this to. I've ripped 200+ dvd's so far and encountered this on about 20 of them. I've also tried them on 3 separate macs and get the same thing. The dvd's play fine.
The log below is from a title I extracted via Mac The Ripper to see if that wouldn't make any difference, it didn't. It does the same via the actual dvd.
MakeMKV v1.6.0 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/macmini/MakeMKV_log.txt
Optical drive "DVD+R-DL PIONEER DVD-RW DVRTS08 Q81F" opened in OS access mode.
Opening files on harddrive at /Users/macmini/Movies/TWISTER/TWISTER Main Feature/VIDEO_TS/
Title #0 was added (36 cell(s), 1:48:11)
Saving 1 titles into directory /Users/macmini/Movies/MacTheRipper
DEBUG: Code 0 at c^}YR2jd+|i0o1:;<6ZMx:213130490
DEBUG: Code 0 at c^}YR2jd+|i0o1:;<6ZMx:213129639
DEBUG: Code 0 at 3Rb:*}B3-^l|WwFu~;l:29394183
DEBUG: Code 0 at kO55^bs+-=`<^:&z>(W:29394160
DEBUG: Code 0 at kO55^bs+-=`<^:&z>(W:29395195
Failed to save title 0 to file /Users/macmini/Movies/MacTheRipper/title00.mkv
How can I troubleshoot this?
MrSqueezles
Post by MrSqueezles »
I'm also getting this error for a disc. The DVD has multiple angles, one for each language. It failed 3 times in MakeMKV, but worked perfectly in DVD Decrypter and IfoEdit (to extract the correct angle)
Opening files on harddrive at F:/Movies - Rip/rip/
Title #0 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Complex multiplex encountered - 18 cells and 4624 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #1 was added (57 cell(s), 2:22:53)
Angle #2 was added for title #1
Title #2 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2/1 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2/2 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2/3 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2/4 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2/5 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2/6 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4/1 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4/2 has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4/3 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4/4 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 was added (1 cell(s), 0:25:49)
Title #8 has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory F:/Movies - Rip/rip mux
Failed to save title 0 to file F:/Movies - Rip/rip mux/title00.mkv
bottleneck70
Post by bottleneck70 »
@Mike
Can you look into the code? I have tried older versions of your prog on discs that i have had problems with on the new version and they work fine. 1.5.4 seems to be okay, but when I tried 1.5.6 there is issues.
zprewitt
Post by zprewitt »
Saving Private Ryan DVD
Saving 1 titles into directory C:/Users/Administrator/Desktop
DEBUG: Code 0 at ~@5:m^JR]n)bnfAgERWSx:213130490
DEBUG: Code 0 at ~@5:m^JR]n)bnfAgERWSx:213129639
DEBUG: Code 0 at ?Jwd0:yMFhs=J"r)VY*:213130122
DEBUG: Code 0 at 'KpGdm~*:Y=-6rTtu7{:29394160
DEBUG: Code 0 at 'KpGdm~*:Y=-6rTtu7{:29395195
Failed to save title 0 to file C:/Users/Administrator/Desktop/title00.mkv
Locked
