Can't Rip Judy
DukeD
Can't Rip Judy
Post by DukeD » Wed Feb 12, 2020 9:33 pm
First time I have been totally stymied. A number of large files, tried each one, none worked. Anyone else have this problem with this disk? Using Win 10 64 bit. Ver 1.14.17 of Make MKV
Re: Can't Rip Judy
Post by Woodstock » Thu Feb 13, 2020 3:58 am
"none worked"
Some hints would be nice, like what error messages you received.
If it's a Lionsgate title, there will be ONE working title, but they screw up the directory pretty bad to make it hard to find some times.
How to aid in finding the answer to your problem: https://www.makemkv.com/faq/item/8
DukeD
Re: Can't Rip Judy
Post by DukeD » Thu Feb 13, 2020 11:35 am
Thanks for your time to address this, I appreciate it.
When I open MKV and have it open the disk, it says
MakeMKV v1.14.7 win(x64-release) started
Title #1 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 2-4 were skipped due to cell commands (structure protection?)
Title #5 was added (16 cell(s), 1:56:16)
Title #6 was added (4 cell(s), 0:09:34)
Title #9 was added (1 cell(s), 0:04:03)
Title #10 has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 was added (18 cell(s), 2:03:03)
Title #23 was added (16 cell(s), 1:56:27)
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 18-18 were removed from title end
Title #24 was added (16 cell(s), 1:58:09)
Title #25/0/2 was added (2 cell(s), 0:13:02)
Title #26 was added (16 cell(s), 1:58:09)
Title #27 was added (16 cell(s), 1:56:28)
Title #28 was added (16 cell(s), 1:58:09)
Title #29 was added (16 cell(s), 1:56:10)
Title #30 was added (16 cell(s), 1:58:09)
Title #32 was added (18 cell(s), 2:03:03)
Title #33 was added (18 cell(s), 2:03:03)
Title #34 was added (18 cell(s), 2:03:03)
Title #35 was added (16 cell(s), 1:58:09)
Title 1 in VTS 17 is equal to title 1 and was skipped
Title 1 in VTS 19 is equal to title 1 and was skipped
And it displays 8 files including 6 that are in excess of 5gb with 16 chapters each. Of course I expect that one of these is the title I'm interested in.
When I try the first one, it runs for in excess of 10 mins and the bars fill about 1/4" green and never advance further, nothing happens and , thus, no error codes or messages. Really perplexing. This same thing happens when I try the 7 other +5 gb files.
Your thoughts? Any further info I might supply to help?
Jeff-Mich
Re: Can't Rip Judy
Post by Jeff-Mich » Tue Feb 18, 2020 11:09 pm
I'm seeing exactly the same thing... I tried all 5 of those 16 chapter titles which varied in size... none interestingly matching the 1:58:12 play time when playing in VLC
In all cases it writes just 4k to the output file and then just seems to hang (though I can abort).
I tried on two different PC's, one Win8 other Win10
Also probably not coincidental VLC also acts oddly... when playing the disc in VLC it goes straight to playing the movie... I can't get to the menu(s)... though I can in PowerDVD
Guess I'll be watching this movie tonight w/DVD player!
d_virtual_one
Re: Can't Rip Judy
Post by d_virtual_one » Wed Feb 19, 2020 3:30 pm
Have the same problem as everyone else.
When using a DVD player seems to play title 35 correctly.
conchshell
Re: Can't Rip Judy
Post by conchshell » Tue Apr 07, 2020 2:57 am
A quick search on "Judy" here led me to this post. I can confirm that [U.S.A Retail PLAYLIST = 00661.MPLS] was the correct playlist on my non-4K Blu-ray disc.
