Error with "The Last Unicorn" DVD
Choque
Post by Choque »
When trying to open the DVD "The Last Unicorn" MakeMKV reports this in the log field on the bottom
MakeMKV v1.6.10 win(x64-release) started
Complex multiplex encountered - 11 cells and 10260 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #0 (1:28:55) was skipped due to navigation error
Also at the top the error occurs when it's in "Current Cell 4/11" and "Current VOBU 4057/10260"
The DVD is on my computer as an ISO and I mount it with DaemonTools. I also tried it with a burned copy of the ISO but it gives the same error. And yes, the burned version and the ISO work without a problem.
setarip_old
Re: Error with "The Last Unicorn" DVD
Post by setarip_old »
Hi!
Actually, MakeMKV prefers to be directly fed UN-mounted .ISO image files instead of mounted .ISO image files...
Post by mike admin »
Please enable debug messages in preferences and post the log.
Choque
Post by Choque »
setarip_old wrote:Hi!
The same happens when loading the ISO directly into MakeMKV
mike admin wrote:Please enable debug messages in preferences and post the log.
Here's the Debug Log
Debug log started at Sun Jun 05 16:51:39 2011 , written by MakeMKV v1.6.10 win(x64-release)
001005:0000 MakeMKV v1.6.10 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Choque/MakeMKV_log.txt
003024:1000 Complex multiplex encountered - 11 cells and 10260 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
001003:0020 DEBUG: Code 0 at JF,?q*?/g&P"h<W"c3:29402302
001003:0020 DEBUG: Code 0 at JF,?q*?/g&P"h<W"c3:213139759
003015:0000 Title #0 (1:28:55) was skipped due to navigation error
Title skip vts=1 pgcn=1 hash=03F224A234703447
Application exited at Sun Jun 05 16:52:28 2011
setarip_old
"Hash" messages are indicative of either a failing drive or dirty/damaged disc...
This line is completely different from a hashcheck error.
From the log it definitely looks like a disc mastering error. To begin, please send all IFO files per instructions at http://www.makemkv.com/faq/item/8/catid/6
Choque
Post by Choque »
Here are the compressed IFOs. Thanks for your help so far :)
Last Unicorn.7z
(21.37 KiB) Downloaded 451 times
